adjusting lifters on a B16?
any one knows if after installing stage 2 cams and high comp valves, springs ad titanium retainers on a B16A ... do i have to adjust the lifters? if so how do i do it , is it hard and how do i know when their adjusted right
theres a special tool u use, its called a feeler gauge i believe. its a thin piece of metal that u stick in between the rocker and the cam lobe. tighten the rocker arm until the sheet of metal is sorta hard to pull out, but not too hard. 6 for intake side and 7 for exhaust side
http://tech.hybridgarage.com/tech/cams.html goto the bottom were it says 'finishing up - valve clearances'
ARE YOU WORKING ON A SBC? (Small Block Chevy) Because last time I looked SOHC or DOHC
motors dont have lifters they have followers. But I'm just giving you crap man.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LsSol »</TD></TR><TR><TD CLASS="quote">does anyone here even builds their motors or is it all ricers here just talking about their new intakes and lights</TD></TR></TABLE>
try this..... http://www.c-speedracing.com/h...t.php
BTW lose that attitude and stop trying to start **** newb, or you won't last long here.
[Ennis_D]
Aug 8, 2007 01:05 PM
