clutch cable problem with b18 swap
Old Jul 26, 2003 | 10:08 PM
89Si's Avatar
Default clutch cable problem with b18 swap
Its not long enough, and everywhere i read, it says i can use the stock one. I have an Si, so is the DXs longer or something? Do i have to modify the Si's in some way? I got a 90-93 cable, but it was the same length. I need this fixed so i can drive to meineke and get this thing streetable. almost done...
Old Jul 26, 2003 | 10:15 PM
Rob R.'s Avatar
Default Re: clutch cable problem with b18 swap (89Si)
The stock CRX one can be modified to work. Here is a web site with the info - it's at the very bottom of the page. This will also work if the Integra one is too tight/short as well.
http://www32.brinkster.com/tjs...l.htm
I was able to use a 90-93 Integra cable and haven't had any problems.
Hope that helps,
Rob
ryanevansoh
Mar 23, 2009 02:02 PM
Nutnwrench
Jun 18, 2008 08:55 PM
EKIM NART
Oct 21, 2005 04:56 PM
sCeRaXn
Mar 26, 2003 05:51 AM
slo2kSi
Feb 18, 2003 06:40 PM
