zc ecu
Im so stoked today...I just got a zc today...... well now my question....What is a better ecu the 89 teg or the 90 teg both obd 0... I would like to hear from people that have actually used the two or either... thanks and what are the gains....
I'm swaping it into my 1990 si hatch... THANKS
When I had my ZC, I tried just about every ecu at some point or another.
The PM7 ran it the best. Most reliable, best power delivery, smooth and predictable. Non of the O2 codes that can happen with the PG7 or PR4
So I couldn't go over 112 mph...that was probably a good thing.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 91civicDXdude »</TD></TR><TR><TD CLASS="quote">90-91 teg ECu is the OBD0 PR4. it will work, but it sucks for the ZC. it only has a 6800 rpm rev limit. get an 88-89 PG7, 7500 rpm rev limit, works great for ZC.</TD></TR></TABLE>
I dunno about that 7500 limiter, my shift rod was real loose when I first did the swap and I mis-shifted and the tach hit 8k. Nothing messed up, pulled one valve slightly out of spec so it ticked but that was fixed easily enough. So i dunno, I know the stock tach can be off but it was definately up there...
sircrxracer
12
Apr 29, 2005 04:04 AM
