Will 90-93 Integra Ground Control Coilovers fit on my 92-95 Civic Hatchback??
90 Integra shocks part# 341136 and 92 hatch part number is the same, so if I had to guess, i'd say they will fit.
So, if they will fit that is awesome. I am wondering if the only difference would be spring rates then. Since I desire a stiffer srping, I guess going with the Integra ones is my choice decision anyways. What do you think?
Modified by importimage at 3:48 AM 7/27/2003
I just put 92-95 / 94-00 Civic/ Teg. Koni's on my 91 integra. The backs bolt on (with the correct 92-94 springs), but I needed the 92-95/ 94-00 front shock forks. The koni's were to big, and did not slip in to the 91 teg forks.
$60 shipped from http://www.sofast.com
Hank
Hank
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by importimage »</TD></TR><TR><TD CLASS="quote">So, if they will fit that is awesome. I am wondering if the only difference would be spring rates then. Since I desire a stiffer srping, I guess going with the Integra ones is my choice decision anyways. What do you think?</TD></TR></TABLE>
Well, with GC, all the rates are custom, so the rate may not neccessarilly be stiffer. You just need to decide what rates you're looking for and buy them if the ones for sale are in that deisred range. HTH
It might be diferent with coilovers (I haven't insatlled a set). However, my friend and I were insatalling our respective sets of Eibach Sportlines on my '90 LS and his '95 EX at the shop at work and his struts and springs were both a couple of inches longer than the ones on my DA...so, I'd have to recommend against it...
I called Ground Control and talked to atech and he said that it is not wise to put 90-93 integra coilovers in a 92-95 civic hatch because they will not lower the car enough. There were other factors too but I guess he did not care to tell me!!
importimage
11
Mar 1, 2012 03:48 PM
h-o-n-d-a
Suspension & Brakes
Feb 17, 2010 09:13 AM
stuie08
Mar 20, 2007 09:23 PM
filthyCREX
Nov 28, 2003 12:30 PM
