What Kind of Motor Mounts would I use for this swap....
Old Aug 5, 2001 | 01:01 PM
Type-ARR's Avatar
Default What Kind of Motor Mounts would I use for this swap....
I want to put a 1989 Integra Ls D16A1 motor into my 89 CRX si.....
What else would I need like what like of harness and axles would work...thx
Old Aug 5, 2001 | 01:24 PM
crx(gator)'s Avatar
Default Re: What Kind of Motor Mounts would I use for this swap.... (ITR-481)
its not worth the time and effort to swap, other than the fact that its dohc, unless you plan on putting jdm zc cams in the engine. but that is a good question though, i have never heard of anybody doing this, usually this swap is done into 1st gen crx's like my crx has it, cause it bolts on to it, but for a 2nd gen i dont know. do you have the engine already or are you going to buy it still?
Old Aug 5, 2001 | 02:10 PM
FOCUSMAN's Avatar
New User
HEY DUDE GET THE LS FROM OCEANA JUNK AND YOU WILL BE READY TO RACE GOOD LUCK WITH THE 200HP CRX. TONY S!!!
Old Aug 5, 2001 | 04:43 PM
brad.'s Avatar
so you plan on doing a ZC motor swap into a Crx? well that's the easiest motor swap to do in your car...but i wouldn't recommend it. the LS motor uses the same mounts as your motor and the same wiring as an Si...yet you would have to use an 89 integ ECU..you can even use your tranny
Old Aug 5, 2001 | 05:58 PM
crx(gator)'s Avatar
Default Re: What Kind of Motor Mounts would I use for this swap.... ([626]JDM-b16a-EF9)
this engine will bolt up to a 2nd gen, i know it will for a 1st, but i thought it had different mounting points compared to a 2nd gen, because you cant put a 2nd gen jdm zc in a 1st gen because of the mounting points.
crxproject87
Mar 27, 2008 07:06 AM
2zwudz
Feb 22, 2008 02:19 AM
4thgenlude
Aug 28, 2005 03:29 PM
vtec_head
Apr 22, 2002 02:26 PM
RICEBURNER1406
Jun 21, 2001 07:12 PM
