What kind of spark plug wires
Old Jul 26, 2003 | 02:46 PM
J2turbo21's Avatar
Default What kind of spark plug wires
I was wondering what kind of spark plugs wires i should use.I got a msd ignition setup and was running them with stock plug wires without problems.Is there a good brand out there or something that doesnt cost $100+ like Nology.
Old Jul 26, 2003 | 03:37 PM
J2turbo21's Avatar
Default Re: What kind of spark plug wires (J2turbo21)
Ok well i did a search and everyone seems to want NGK blue wires.But i couldnt find an answer for someone with msd ignition installed.
Old Jul 26, 2003 | 03:54 PM
LSiTurbo's Avatar
NGK or MSD
Old Jul 26, 2003 | 03:55 PM
Mr Hammond's Avatar
a/k/a Jomo
I always recomend OEM or NGK blues if you aint got the $$. If you are running around 400+whp or you just happened to have an MSD set-up why not run the MSD 8.5mm wires?
Old Jul 26, 2003 | 04:01 PM
J2turbo21's Avatar
Default Re: What kind of spark plug wires (Mr Milano)
Yea i just dont want to spend 80bux on some plug wires.I have heard and seen pics and it looks liks ERE doesnt use msd so i figure just sell my setup and run stock ignition.
Old Jul 26, 2003 | 04:11 PM
Mr Hammond's Avatar
a/k/a Jomo
Well I didn't want to say anything........
Old Jul 26, 2003 | 04:17 PM
J2turbo21's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mr Milano &raquo;</TD></TR><TR><TD CLASS="quote">Well I didn't want to say anything........</TD></TR></TABLE>
What do you mean?
Old Jul 26, 2003 | 04:19 PM
Mr Hammond's Avatar
a/k/a Jomo
Hahha. Nothing man. I was just going to advise you to ditch the MSD and run all OEM Honda. I didn't want to be a dick or anything.
Old Jul 26, 2003 | 04:21 PM
J2turbo21's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mr Milano &raquo;</TD></TR><TR><TD CLASS="quote">Hahha. Nothing man. I was just going to advise you to ditch the MSD and run all OEM Honda. I didn't want to be a dick or anything. </TD></TR></TABLE>
Its cool bro as long as you wont being an *** about it.I trust your opinion,i always see you give good info out and it seems like you know your stuff.I think i might just do that
Old Jul 26, 2003 | 04:29 PM
Mr Hammond's Avatar
a/k/a Jomo
Right on. I've tested the typical MSD set-up (MSD 6A, Blaster 2/3/SS, mod cap, 8.5mm wires and Denso's/NGK's) on anything from a bone stock 92 Accord LX to N/A monsters to boosted cars as well. To be honest there are so minimal gains in throttle responce/fuel consumption etc... Not worth it on Honda's IMHO. When it comes time to upgrade, you are probably ready for a Digital 7 anyways.
Old Jul 26, 2003 | 04:47 PM
J2turbo21's Avatar
Coo im gonna ditch the msd and run stock.I could use that money for something else right now anyways.Thanks
Old Jul 27, 2003 | 02:22 PM
AzG35's Avatar
Its funny, one of my MSD wires broke off completely at the distributor last night. The actual L piece that goes into the boot snapped off. Gonna go back to OEM.
Old Jul 27, 2003 | 03:24 PM
Big Teggie's Avatar
NGK or Stock work good.
Old Jul 27, 2003 | 03:47 PM
FF-sean's Avatar
Default Re: What kind of spark plug wires (Big Teggie)
NGK all da way.....
but if you got some money to spare...go with SPOON
Old Jul 27, 2003 | 03:48 PM
FF-sean's Avatar
Default Re: What kind of spark plug wires (ReaL JDM Eg6)
stock is better
Old Jul 27, 2003 | 06:53 PM
Atheist's Avatar
I actually use moroso cables
Old Jul 27, 2003 | 08:24 PM
F1Spec's Avatar
oem
Old Jul 28, 2003 | 02:10 PM
sweet's Avatar
Default Re: What kind of spark plug wires (s2geezy)
last year i ran an MSD ignition setup on my B18C motor (since i was using N2O DP injection with it) and had no problems. MSD SCI, SS coil, cap and Magnecor wires.
everything is still in since i was going to go turbo with the new motor, but it's all currently bypassed and i'm only using the stock cap/coil and the old Magnecor wires for now. i have a new set of Magnecor wires to use, along with a new MSD cap and OEM rotor.
but if i stick with N/A then i'll prolly put the new OEM dist. cap i have on and run OEM wires as well. no real need for 'upgraded ignition' unless running some crazy F/I setup.
Boosted_JDM
Jun 14, 2007 07:15 PM
GraphiteMW
Nov 7, 2006 03:55 PM
KekeK-18
Mar 29, 2004 05:40 PM
crxsirvtec
Sep 10, 2003 08:53 PM
redline201
Apr 7, 2003 09:27 AM
