Running GSR pistons with ITR head and intake manifold
Pros and Cons what do you guys think about running a type r head and intake manifold on a b18c1 block and keeping the bottom internals gsr
i swear, you need to research this stuff before you start spitting out combonations and asking opnions. putting a b16/type r head on a GSR block is called a poor mans' type r. read read read.
yeah I have researched it and there nothing wrong with it just woundering how the motor would handle gsr pistons since the type r is the same block as the gsr just diff compression pistons
i'm pretty sure it'd work fine..since people do vice versa (jdm itr pistons in a gsr block..and etc)
but you'd just lower your compression...ultimately losing power.
i think you'd have to ditch the gsr ecu for it to run better?
unless yer going FI...lower compression is better i guess..
waynesumner
10
Feb 16, 2017 02:13 PM
RustyRex
Oct 22, 2003 07:39 AM
SPOON 1
Jul 26, 2003 03:20 PM
