mpfi swap - need help with coolant and vacuum line routing
wiring is done. everything is installed but i need some help with vacuum and coolant lines
theres a large line that comes from just below the manifold. on the dx mani it comes up does a 180 degree turn and plugs in on the 2 or 3 runner (i forget which). where does this go now? im thinking this is the pcv line and it goes to the center port on the a6 manifold but the hose is too big.
the lines to the eacv are coolant, not vacuum right?
orange braided hose... (charcoal canister right?) the one hose is still on from before. the other hose runs to the vacuum port on the tb closest to the firewall... is that right? should i just cut it down to the correct length?
and do i need the purge cutoff solenoid valve to route things correctly (second cannister kinda thing by the map sensor)? i have it, but i didnt install it as of yet
i think thats about it for now.
Modified by tylerspec at 7:42 PM 7/26/2003
SlipGear
Jan 19, 2008 02:33 PM
