just installed JDM sidemarkers. . question
Old Jul 26, 2003 | 12:55 AM
jonoknut's Avatar
Default just installed JDM sidemarkers. . question
i put in my JDM sidemarkers today and wired them all up. now my question is, are they supposed to be on whe your headlights are on? I just assumed they wouldn't be but they were. anyone know how it is in japan? i kind of like them on, but then at the same time i feel like i have some underbodys glowing or something. .thanks,
jon
Old Jul 26, 2003 | 12:58 AM
The-LS's Avatar
Default Re: just installed JDM sidemarkers. . question (jonoknut)
they are supposed to only signal, some people wire markey lights to steady burn as parking lights and signal as well. Its eye catching at nite... that can be good or bad... depending on who is looking.
Old Jul 26, 2003 | 05:56 AM
Modifiyem's Avatar
Hey Jon,
I was planning on putting those jdm side markers on my car for the signal purposes since I don't have any signal lights in my front bumper. Can you send me some pics if you have any? One more question; where did you get them and how much are they?
Thanks,
ersenalci@comcast.net
Old Jul 26, 2003 | 11:22 AM
JDC2's Avatar
Default Re: (Modifiyem)
in japan no amber is on when the headlights are on. only on when you signal.
Old Jul 26, 2003 | 11:56 AM
jisecup's Avatar
splice them into one of the wires from ur bumper lenses. i forget what wire it is.
mine are wired for only signal. much better looking imo.
Old Jul 26, 2003 | 12:14 PM
B2FiNiTY's Avatar
Default Re: (jisecup)
They should be wired to only turn on when you signal. The only way and the best way.
Old Jul 26, 2003 | 12:18 PM
illi Adik's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jisecup &raquo;</TD></TR><TR><TD CLASS="quote">splice them into one of the wires from ur bumper lenses. i forget what wire it is.
mine are wired for only signal. much better looking imo.</TD></TR></TABLE>
Old Jul 26, 2003 | 04:09 PM
typeR#0427's Avatar
Default Re: (B2FiNiTY)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B2FiNiTY &raquo;</TD></TR><TR><TD CLASS="quote">They should be wired to only turn on when you signal. The only way and the best way.</TD></TR></TABLE>
Thats what I did with mine. I just wired them directly to the front signal lights. Looks amazing. My favorite apperance mod so far. (well except the wheels )
Old Jul 26, 2003 | 08:40 PM
jonoknut's Avatar
Default Re: (hamB18C1)
i did wire mine to the front turn signal but as soon as i turn my lights, (one click or two) the sidemarkers come on. should it be wired to the inside half(facing forward) or the outer part of the signal? either way both lights are on when my headlights are on so im not sure how im gonna do this.. .
jon
Old Jul 26, 2003 | 09:06 PM
threatcon13's Avatar
New User
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B2FiNiTY &raquo;</TD></TR><TR><TD CLASS="quote">They should be wired to only turn on when you signal. The only way and the best way.</TD></TR></TABLE> it's not the ONLY way, you can wire them up so they are on at all times but that is not oem.
Old Jul 26, 2003 | 09:54 PM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
Default Re: (Threatcon13)
you can also wire them to be both on and flash as turn signals, but they will flash opposite the turn signals if the parking lights are on.
IMHO it looks retarded like that, just wire them as turn signals like they should be.
Old Jul 27, 2003 | 01:03 AM
jonoknut's Avatar
Default Re: (PatrickGSR94)
i want them just turn signals. . . but i dont know where to wire it to?
jon
Old Jul 27, 2003 | 08:55 AM
98R-1144's Avatar
Default Re: (jonoknut)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jonoknut &raquo;</TD></TR><TR><TD CLASS="quote">i want them just turn signals. . . but i dont know where to wire it to?
jon</TD></TR></TABLE>
you need to splice to the HIGH power wire to your front blinker (i'm assuming you have a 98+ DC2). The front blinker bulb (the big one) has 3 wires coming out of it... HIGH power (the flash when blinking), LOW power (the steady ON... aka parking light), and GROUND.
You should probably use a volt meter to know which one is the HIGH (I guessed and got lucky..lol). Then wire up the sidemarker using the HIGH and GROUND... voila... instant turn signal sidemarker.
EDIT: Crap you have a 95 GSR. I'm not really sure, but I'm almost positive both the bulbs in the bumper lens blink? If one of the bulbs have 3 wires, it should be good to go. Otherwise, find the bulb that is never on but only blinks, and use those wires
Old Jul 27, 2003 | 10:29 AM
jisecup's Avatar
Default Re: (98R-1144)
its the same with 94-97.
hook the ground up to the ground wire that is provided for the bumper lenses, then take it to the high powered one. just get some T-Taps from lowes or where ever,and tap into the wire. if its not that wire, take it off, put tape on it, and try the other wire.
unless u have a voltmeter.
Old Jul 27, 2003 | 11:42 AM
Community Builder
On the 94-97 cars the smaller side bulb in the bumper lens functions the same way as I described above, flashes with turn signal, on w/ parking lights, but flashes opposite the turn signal if the parking lights are on. I think it looks retarded (especially when you also have sidemarkers that are only turn signals) so I rewired the small bumper lens bulb to be a parking light only. It never flashes now, and is only on when the parking lights are on. IMHO it looks much better that way.
Bryro22
Lighting
May 14, 2008 08:43 PM
99CivicSiBrian
Jan 10, 2006 08:26 PM
V-Thang
Acura TL, RL & ZDX
Mar 11, 2004 03:41 PM
chingchong
Sep 11, 2002 08:35 AM
Nighthawk GS-R
Jul 12, 2002 07:25 PM
