just changed fast idle thermo valve on a '90 accord ex, still having the erratic idle problem
it was fine when i turned it on and then when i turned the headlights on the idle went up 2000rpm and then back down to 1500 and it continuosly went up and down like that until i turned off the lights.
what is going on? should i check the timing as well?
TIA
TIA
why did u changed fast idle thermo valve? '
if u did that,,,,,could of you did not install the gasket,,,,,anyway,,,,,,look for vacuum leaks.......dude....
SlackerAccord
Sep 22, 2005 08:49 PM
