rotor replaced 100.00
Guest
Posts: n/a
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by x00gsr »</TD></TR><TR><TD CLASS="quote">How many rotors are being replaced? You can buy a blank rotor at autozone for 25 bucks. </TD></TR></TABLE>
Just the front part and labor or i buy the parts and i'll give your 20.00 to slap it on ahahah
Just so you know, replacing rotors on an Integra is as simple as this:
-Remove wheel
-Remove rotor screws ($10 impact driver from Harbor freight)
-Lift up caliper
-Replace rotor
-Put caliper back
-Lug the wheel
$100 ain't bad if it's for parts and labor. I think you could do it yourself and save $50 though.
-Remove wheel
-Lift up caliper
-Replace rotor
-Put caliper back
-Lug the wheel
Guest
Posts: n/a
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tweakmeister »</TD></TR><TR><TD CLASS="quote">Just so you know, replacing rotors on an Integra is as simple as this:
-Remove wheel
-Lift up caliper
-Replace rotor
-Put caliper back
-Lug the wheel
$100 ain't bad if it's for parts and labor. I think you could do it yourself and save $50 though.</TD></TR></TABLE>
sound easy never try before but i think i will this time
-Remove wheel
-Lift up caliper
-Replace rotor
-Put caliper back
-Lug the wheel
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Spoon_b18 »</TD></TR><TR><TD CLASS="quote">
sound easy never try before but i think i will this time</TD></TR></TABLE>
And please, have a manual in hand when doing this...like a Helms or if you cannot afford that, a Haynes will absolutely do.
RicksJdmCivic21
Mar 22, 2004 04:18 PM
navin
Nov 11, 2003 02:28 PM
