Tein/Suspension Question
Old Jul 25, 2003 | 12:20 PM
RiCE On IcE 2's Avatar
Default Tein/Suspension Question
I am about to put the FLEX on my R. According to Teins website the standard setting will lower the front 1 inch and the back 1.4 inches. Do most coilover setups come set up so that the rear is lowered more? I woulda though the rear would be lowered less.
How do u torque the lower bracket? Or do u torque it against the lower bracket lock?
Old Jul 25, 2003 | 12:30 PM
Flux's Avatar
Default Re: Tein/Suspension Question (RiCE On IcE 2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RiCE On IcE 2 &raquo;</TD></TR><TR><TD CLASS="quote">I am about to put the FLEX on my R. According to Teins website the standard setting will lower the front 1 inch and the back 1.4 inches. Do most coilover setups come set up so that the rear is lowered more? I woulda though the rear would be lowered less. </TD></TR></TABLE>
I'm not sure what you mean by 'standard setting' - maybe they are referring to how they are set out of the box. Coilovers allow you to make very small adjustments at each corner of the car independently, there are no 'settings'.
You're best bet is to set it all around ata good ride height and then get the car corner weighted, making small adjustments at each corner until it is balanced.
Old Jul 25, 2003 | 12:33 PM
Default Re: Tein/Suspension Question (Flux)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Flux &raquo;</TD></TR><TR><TD CLASS="quote">
You're best bet is to set it all around ata good ride height and then get the car corner weighted, making small adjustments at each corner until it is balanced.</TD></TR></TABLE>
Oh i meant the preset height they are at when they leave the factory.
Old Jul 28, 2003 | 12:57 PM
I installed the FLEX but had a quick question. Is there a problem with adjusting ride height via the lower bracket? Reading the manual it seems liek tein tells u to do it via the spring locks and wut not. But then wouldn't reduce the strat travel?
Old Jul 28, 2003 | 06:07 PM
Asahi's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RiCE On IcE 2 &raquo;</TD></TR><TR><TD CLASS="quote">I installed the FLEX but had a quick question. Is there a problem with adjusting ride height via the lower bracket? Reading the manual it seems liek tein tells u to do it via the spring locks and wut not. But then wouldn't reduce the strat travel?</TD></TR></TABLE>
Doesn't make sense to buy the FLex and not use the lower adjustment. Changing the preload for height adjustment is silly. IF you need reassurance call TEIN.
Old Jul 28, 2003 | 06:54 PM
janet.k2's Avatar
this forum as always has great info! I have a quick question, sorry if it's a stupid question, where do you get your car corner-weighted? Mahalo!
Old Jul 28, 2003 | 11:54 PM
Default Re: Tein/Suspension Question (Asahi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Asahi &raquo;</TD></TR><TR><TD CLASS="quote">
Doesn't make sense to buy the FLex and not use the lower adjustment. Changing the preload for height adjustment is silly. IF you need reassurance call TEIN.</TD></TR></TABLE>
yea thats what I was figuring... but then the manual seems to lean towards adjusting by the seat lock which would void the whole bottom bracket thing ... well neway I did it via the bottom bracket
Old Jul 29, 2003 | 05:23 AM
Maximus's Avatar
Tighten the two spring seat locks as tight as possible, but try not to over tighten them. You can adjust the flex using the bottom shock if you unscrew the spring lock located right above the shock.
Old Jul 31, 2003 | 12:46 AM
Default Re: Tein/Suspension Question (Maximus)
turning the shock body clockwise into the lower bracket should lower the car right? I swear I did that for days and it's the same height?
redlinexd
Apr 2, 2011 12:01 PM
DB_2o3
Suspension & Brakes
Sep 23, 2008 09:42 AM
Pompiuses
Feb 18, 2005 01:27 PM
jansenrw
Sep 21, 2003 06:59 PM
