What is the difference between 5th and 6th gen rear dampers?
Old Jul 25, 2003 | 09:29 AM
Civiclx's Avatar
Default What is the difference between 5th and 6th gen rear dampers?
I know the fronts are the same but someone said that the rears are a little different where the damper is attached to the LCA. Is it a wider stance on the 6th gen or vice versa? is there any way to swap the shocks from a 5th gen to a 6th gen or vice versa? Thanks guys!
Old Jul 25, 2003 | 09:51 AM
sammysnakes's Avatar
Default Re: What is the difference between 5th and 6th gen rear dampers? (Civiclx)
the 5th gen LCA bushing is bigger than the 6th gen. so you'll need to shave the bushing down if you're swapping onto a 5th gen.
Old Jul 25, 2003 | 10:00 AM
Civiclx's Avatar
Default Re: What is the difference between 5th and 6th gen rear dampers? (chainsaw)
so how would i go about swapping 5th gen rear shocks to a 6th gen? should i get bigger bushings? or can i compleltely swap the rear lca from a 6th gen
Old Jul 25, 2003 | 10:31 AM
the 6th gen LCA is longer than the 5th gen, so it can't be swapped. just put some washers on either side of the bushing on the 6th gen LCA. that should work.
jmm96gsr
Jun 18, 2007 12:37 PM
Halo
Jan 22, 2006 02:34 PM
shadowz
Jun 14, 2004 12:04 PM
Fly1865
Sep 21, 2002 02:21 PM
AccordDriver92
Jul 16, 2002 02:59 PM
