Poor mileage caused by coolant temperature sensor?
Old Jul 25, 2003 | 09:14 AM
pentaq's Avatar
Default Poor mileage caused by coolant temperature sensor?
Hi,
It's been quite long time I have a poor mileage in my 94 VTEC. I can only drive 250miles to make the tank empty. I did care to drive very soft and easy while testing my mileage and it didn't change...
So few days ago I went to dealership and had a diagnostic computer connected. It appeared that coolant temperature sensor (this one in the block under distributor) sends fake readings to ECU. Fans start normally when engine is hot but sensor shows only 78 degrees centigrade. We couldn't even achieve 80 degrees to perfom whole test So I think that this sensor is cheating ECU and ECU "thinks" that engine is still cold and I'm running too rich and that's the cause of that poor mileage. What's your opinions about that? I'll be replacing this sensor ASAP BTW.
Thanks
pentaq
Old Jul 25, 2003 | 10:32 AM
Sephro's Avatar
Default Re: Poor mileage caused by coolant temperature sensor? (pentaq)
I think you started off with the question gave your suggestion and confirmed it. What do you want to know? Yes replace it.
Old Jul 25, 2003 | 11:31 AM
CHK4TIX's Avatar
Default Re: Poor mileage caused by coolant temperature sensor? (Sephro)
i only get 250 miles per tank
stocker2shocker91
Nov 2, 2012 06:45 PM
ahloung
Mar 15, 2006 11:59 AM
dasistheone
Jan 20, 2006 10:54 PM
Adam_F123
Mar 18, 2004 05:18 AM
brian estrada
Apr 5, 2003 09:01 AM
