Help with honda running badly....ideas please!
Old Jul 25, 2003 | 08:37 AM
brimy311's Avatar
Default Help with honda running badly....ideas please!
i have an 87 honda accord, LXi efi....anyways....
when you are driving after it has warmed up a little, it will start bogging down, like you press the gas and just boggs, some times you have to completely stop the car and rev it up a little to get it to start running clean again...
i have changed the spark plugs and the fuel filter...anyone ever have this problem?
Old Jul 25, 2003 | 12:36 PM
WuWarrior's Avatar
Default Re: Help with honda running badly....ideas please! (brimy311)
It could be anything. Check your air filter. Look at the exhuast for any big dents and make sure the catalytic converter is not clogged. Check the PCV valve. Are you getting a check engine light?
Take it somewhere to have a technician troubleshoot it for you.
Old Jul 25, 2003 | 01:22 PM
brimy311's Avatar
Default Re: Help with honda running badly....ideas please! (WuWarrior)
there is not a check engine light....i should pull the pvc and look at that....let me take a look and get back to you
Old Jul 25, 2003 | 02:14 PM
YeuEmMaiMai's Avatar
simple things
fuel injector cleaner
fuel filter, fuel pump (it may be failing when it gets hot)
any one of the sensors.....
Old Jul 25, 2003 | 06:54 PM
Stripped Honda's Avatar
99-0104
Default Re: Help with honda running badly....ideas please! (YeuEmMaiMai)
i bet it is the cat it is clogged or if not it is a plugged fuel filter ... to check the cat remove it and start the car see if it revs up alot better
Old Jul 25, 2003 | 07:56 PM
NathanMorris's Avatar
Default Re: Help with honda running badly....ideas please! (Stripped Honda)
check the fuel system and the exhaust for blockage.
-Nathan
Old Jul 26, 2003 | 07:17 AM
brimy311's Avatar
Default Re: Help with honda running badly....ideas please! (92Lx)
it only does it when runnin at like 45mph-up. It runs great in the driveway and up to 45mph.
Old Jul 28, 2003 | 04:39 AM
JimBlake's Avatar
You might be able to see if the cat is plugged. Take it out & look thru it. You should be able to see thru the holes, at least where the pipe openings are. Look to see if the ceramic monolith is warped, cracked, loose, rattling, etc...
Revving the engine to 6k in neutral doesn't produce nearly as much exhaust flow as actually driving. The engine's not doing any work, so you don't need to open your throttle very much to rev to 6k in neutral.
PS, a couple more thoughts...
You got new spark plugs; how about wires & distributor cap? Check for arcing. Measure the primary & secondary resistance of your coil. If your coil is getting 'weak', it can show up only at higher rpms.
In '87 the EFI control was kinda crude compared to today. Just because you aren't getting a CEL, doesn't mean you don't have to check ALL the normal tune-up stuff.
Modified by JimBlake at 8:50 AM 7/28/2003
Dale S
Honda Accord (2013 - 2015)
Apr 10, 2019 09:13 AM
csckwade
Dec 28, 2012 11:01 AM
jdm mini me
11
Mar 28, 2010 05:22 PM
blk_eg4
Aug 3, 2006 08:27 PM
trianglegreg
Oct 26, 2005 03:47 PM
