d15b vtec questions...
I don't know too much about these engines except that they compare to the Z6's. Do they respond well to boost? What ECU do I need to run one of these in a 92' VX? Thanks.
make sure you have the d15b thats from VTi not the ETi (d15z1/VX) version which would just be a direct replecment.
P28 will work just fine, but it seems not to offer full potential of the motor.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by v4lu3s »</TD></TR><TR><TD CLASS="quote">wouldnt the p08 work better since it controls all 3 stages of vetc instead of just 2?</TD></TR></TABLE>
all OBDI D15B sohc vtecs were 2 stage, 3 stage started on the EK/96+ JDM civics, P08 is just a 'regular' sohc vtec ecu.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by eg6ajk »</TD></TR><TR><TD CLASS="quote">make sure you have the d15b thats from VTi not the ETi (d15z1/VX) version which would just be a direct replecment.
all OBDI D15B sohc vtecs were 2 stage, 3 stage started on the EK/96+ JDM civics, P08 is just a 'regular' sohc vtec ecu. </TD></TR></TABLE>
that is right
plus, if you use p28, i have heard your mileage goes down the drain..
valve cover should be VTEC on the top, look for the solenoid aswell
that is right
loudsubz
18
Apr 29, 2004 03:56 AM
