Bolt pattern of the flange on DC JDM header?
Old Jul 25, 2003 | 07:59 AM
HondaJon's Avatar
Default Bolt pattern of the flange on DC JDM header?
I am buying a DC JDM header, and need to know what the flange pattern is so that I can buy the right high flow cat to attach it to.
Thanks in Advance,
JP
Old Jul 25, 2003 | 12:44 PM
HondaJon's Avatar
Default Re: Bolt pattern of the flange on DC JDM header? (HondaJon)
I know that there is more than one person in this forum with this header?
Could somebody please help me out?
Thanks,
JP
Old Jul 25, 2003 | 01:20 PM
SlapSmak's Avatar
JP, it is the standard 2 bolt flange, but it has a 2.5" collector. The donut gasket you will need is the 2.5" gasket used on the S2000 exhaust manifold, 22$ at Honda. The Cat you need will have to be custom, 2.5 at the header end and setup for the 2.25 USDM bpipe connection. I can HIGHLY recommend that you IM Dave (SMSP) he has a jig and exact dimensions and will make you a custom high flow cat that will fit perfectly. he will even include new bolts, retaining springs and bpipe gasket. I have this setup on the Yellow and it is awesome. Also, the USDM header bracket will crack if you attach it to the JDM DC, so dont even use it.
Old Jul 25, 2003 | 05:15 PM
SurferX's Avatar
I second not using the header bracket on the DC JDM, mine tore in half and the car sounded terrible until I finally found what it was and removed it.
Old Jul 26, 2003 | 08:22 AM
HondaJon's Avatar
Default Re: Bolt pattern of the flange on DC JDM header? (SlapSmak)
Thanks for the info SlapSmak, very helpful.
I am going with a custom 2.5 inch exaust however with the new header, and this will eliminate the need for a special cat I would assume.
I would like to go with something from SMSP, but at this time I don't think its in the budget. I am going with mandrel piping, cat, resonator, and magnaflow muffler from KTeller8 right here on Honda-Tech.
Thanks Again guys,
JP
Old Aug 18, 2003 | 12:59 PM
DsITR's Avatar
Bringing this thread back from the dead.
Just verifying to see if the DC JDM 4-1 flange is in fact 2 bolt?
TIA
Old Aug 18, 2003 | 01:15 PM
Padawan's Avatar
Darth ModerVader
Default Re: Bolt pattern of the flange on DC JDM header? (DsR)
Good shot of the DC JDM 4-1 collector flange:
pchan
Mar 3, 2007 06:37 PM
QuestRacingType-R
Dec 5, 2001 11:34 AM
lePetitePrince
Oct 11, 2001 10:56 AM
EleanoR
Sep 17, 2001 03:45 PM
GSR
Aug 19, 2001 11:01 PM
