Will 270cc injectors be good for my setup?
Old Jul 25, 2003 | 07:14 AM
VtecDA9's Avatar
Default Will 270cc injectors be good for my setup?
ls/vtec 11.6-96c/r... milled .030 b16 head with GSR cams, ITR IM, 62mm tb, .25 over ITR pistons, decked block .008... DC 4-2-1, 2.25 exhaust, vision chipped p28, LS fuel pump, b&m fpr...
Old Jul 25, 2003 | 07:26 AM
IN VTEC's Avatar
Default Re: Will 270cc injectors be good for my setup? (VtecDA9)
You might as well get 310cc injectors. They're not that much more...like a couple bucks more per injector for the RC's. Probably similar price structuring for other brands...MSD, Siemens, etc.
Stock injectors will be ok for now, but if you go with any bigger cams, you might as well get the bigger 310cc's.
Even with ITR cams, I'm having a hard time with leaning out on stock injectors, using a VAFC and adj FPR at 60psi static pressure. But, I don't have a chipped ECU, which extends the limits using a stock 240cc injector fuel system.
Old Jul 25, 2003 | 11:22 AM
VtecDA9's Avatar
Default Re: Will 270cc injectors be good for my setup? (IN VTEC)
If ur having a hard time leaning out, why don't you just drop our fuel pressure... doens't that seem kinda high? 60psi....
Old Jul 25, 2003 | 11:54 AM
sleeper4dr's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by IN VTEC &raquo;</TD></TR><TR><TD CLASS="quote">I'm having a hard time with leaning out on stock injectors,</TD></TR></TABLE>
Old Jul 25, 2003 | 02:07 PM
IN VTEC's Avatar
Default Re: Will 270cc injectors be good for my setup? (sleeper4dr)
Thanks for clarifying that. It leans out b/w 6000 and 7000 rpm to high 14:1 AFR's. That's with the fuel pressure turned up to 63psi static pressure.
I won't be going higher than 65psi. From what I've read, the stock fuel pump doesn't like anything close to 75psi of rail pressure.
88LXi68
Jul 7, 2009 12:36 PM
allnaturalb16
Oct 16, 2006 01:51 PM
riceball777
Feb 25, 2004 09:35 AM
CRXEE8
Sep 24, 2003 04:54 AM
