bad miss in my zc?
Old Jul 25, 2003 | 07:11 AM
kingrex's Avatar
Default bad miss in my zc?
my zc has got an bad miss only at 4500 rpm?if i'm accelerating it will jump and lose power there and now in the 1/4 mile i'm losing 3 mph i cant figure out whats wrong,i changed the plugs wires,dizzy cap,and the rotor button,can anyone help?
Old Jul 25, 2003 | 07:12 AM
manson's Avatar
Default Re: bad miss in my zc? (kingrex)
have you tried doing a valve adjustment? my gsr used to skip out around 2500 and 3000 rpms. once i had the valve adjustment done :thanks tbone: it ran perfect. lost all hesitation and she just ripped after that.
give it a shot.
Old Jul 25, 2003 | 07:27 AM
kingrex's Avatar
ok i looked around would you happen to know the tourque specs for the zc valves?
Old Jul 25, 2003 | 08:41 AM
manson's Avatar
Default Re: (kingrex)
i would look them up for a 89 integra ls. they have the same motor except the zc has different cams and compression. if i remember correctly.
same d16 motor
Old Jul 25, 2003 | 09:03 AM
slywfbpsi's Avatar
CYLINDER HEAD
Material -- Light Alloy
Thickness
New -- 132.0mm (5.20in)
Minimum after resurfacing -- 131.8mm (5.19in)
Maximum surface distoration -- 0.05mm (0.002in)
Valve seat angle -- 45O
Valve seat width (both intake and exhaust)
Minimum -- 1.25-2.00mm (0.049-0.08in)
Max -- 2.0mm (0.08in)
VALVES
Stem diameter
Intake -- 6.55-6.59mm (0.258-0.2594in)
Exhaust -- 6.52-6.56mm (0.257-0.2583in)
Stem-to-guide clearance
Intake -- 0.02-0.08mm (0.001-0.003in)
Exhaust -- 0.05-0.11mm (0.002-0.004in)
Valve clearance
Intake -- 0.13-0.17mm (0.0051-0.0067in)
Exhaust -- 0.15-0.19mm (0.0059-0.0075in)
Valve spring free length
Intake -- 44.8-45.8mm (1.76-1.80in)
Exhaust -- 46.1-47.1mm (1.81-1.85in)
Old Jul 25, 2003 | 10:21 AM
kingrex's Avatar
Default Re: (slywfbpsi)
thanks alot helped me out
Old Aug 2, 2003 | 09:04 AM
kingrex's Avatar
well i figured it out it was the fuel filter
91ZCsi
Feb 22, 2005 11:37 PM
SiRWannabe
Jan 26, 2003 10:21 PM
CimorelliCRX
Mar 8, 2002 05:35 PM
