CTR Cams in a b20vtec (b20b block + b16a2), will the valves clear the pistons?
Just wondering if anyone knows if these cams will make the valves hit the pistons?
Also wondering, what kinda cams could I use that would be better?
Will ITR, Skunk 1 clear?
thanks again,
mike
thanks again,
mike
you cant really ask around and if someone says its ok and just do it, then your asking for trouble. you gotta clay your motor with any non-stock combo.
Thats a negative.
Stock b16a cams won't clear if you have the 9.6:1 compression motor.
Did you get your intake valve reliefs cut?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Rob »</TD></TR><TR><TD CLASS="quote">Thats a negative.
Stock b16a cams won't clear if you have the 9.6:1 compression motor.</TD></TR></TABLE>
if the stock b16a won't clear, the ctr's DEFINETLY won't clear either.
umm,i have b16a2 cams right now..i asked the guy that did it and he said he didn't modify the reliefs.
B20b block
mike
ne1 else with info?
B20b block
mike
ne1 else with info?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MikeMAN »</TD></TR><TR><TD CLASS="quote">umm,i have b16a2 cams right now..i asked the guy that did it and he said he didn't modify the reliefs.
B20b block
mike
ne1 else with info?</TD></TR></TABLE>
But what year b20b block? I bet its the 8.8:1 compression in which case I believe b16a cams will work, but ITR/CTR's will hit on the intake side. Your best bet if you want bigger cams is to get the intake valve reliefs cut out and go to some CTR or ITR cams. Your car will love you for it.
B20b block
mike
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MikeMAN »</TD></TR><TR><TD CLASS="quote">yea, its the low compression one. So do u know what the biggest cam i can run on the exhaust side is?
thanks a bunch rob!
mike</TD></TR></TABLE>
I've heard that an ITR cam will hit on the intake side but not the exhaust side. I'm not sure tho, so you should get a second opinion. I'll try and find some more info for you now.
thanks a bunch rob!
the exhaust valves are the same size vtec/non vtec. the intakes are the bigger ones so it will hit the intake side. im pretty sure that you can get it to work with either the p3f 8.8 or phk 9.6 pistons because its the dish of the piston thats different between the 2 not the valve relief. its just REAL close on both motors. i think that either way with an itr cam your askin for trouble so enlarge them pistons.
</TD></TR></TABLE>you'll need to cut the valve reliefs if you plan on running, 99+ ITR cams or CTR cams. you can run up to 98 ITR cams on a b16 head, and a b20z bottomend! with the b20z bottomend, and a gsr head, i was stock to only being able to use 1st gen b16 cams(nothing bigger)! there are a couple of people in this board, running stock bottomends with toda/skunk2/jun cams. they run these cams by cutting the valve reliefs in the pistons, this is what i'm planning to do to my pistons!
Rtboy10
11
Jul 16, 2009 04:05 PM
Rtboy10
Jul 16, 2009 01:01 PM
