B20 swap, tips/info?
Old Jul 25, 2003 | 06:09 AM
C ronic's Avatar
Default B20 swap, tips/info?
Planning on swapping a B20+GSr tranny into my EK. Wondering if there was anything I should lookout for?
I know Im going to need a driverside upper mount, rear bracket, linkeage(LS?) and LS intake manifold (going with skunk2).
What kinda power tips can I get just goin N/A and non-VTEC. Not looking to be a high reving power monster. Just looking for around 130whp and adding a 50 shot for the weekends.
Going to be using a DC header, skunk2 IM, short ram intake, cam gears, and stage 2 crower cams, with possibly a mild cleanup in the head. sticking with stock LS redline and fuel maps, and compression ratio.
Also do I use an LS shift linkage? Or will the stock EX linkage work?
This is going to be a daily beater w/ ac and stuffs.
tankya for info.
Modified by C ronic at 4:07 PM 7/25/2003
Old Jul 25, 2003 | 07:31 AM
SpyderZEX's Avatar
Default Re: B20 swap, tips/info? (C ronic)
Search!
Old Jul 25, 2003 | 07:49 AM
C ronic's Avatar
Default Re: B20 swap, tips/info? (SpyderZEX)
I did. I was asking for aditional info, but thanks for your help.
Old Jul 25, 2003 | 12:04 PM
eg_type_r93's Avatar
b20 = not reving high
Old Jul 25, 2003 | 12:27 PM
b20_ed's Avatar
Default Re: (eg_type_r93)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by eg_type_r93 &raquo;</TD></TR><TR><TD CLASS="quote">b20 = not reving high</TD></TR></TABLE>
And? Vaguely put
Old Jul 26, 2003 | 10:51 AM
smokey2.0's Avatar
so what's your point?
Old Jul 26, 2003 | 10:57 AM
smokey2.0's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by C ronic &raquo;</TD></TR><TR><TD CLASS="quote">Planning on swapping a B20+GSr tranny into my EK. Wondering if there was anything I should lookout for?
tankya for info.
Modified by C ronic at 4:07 PM 7/25/2003</TD></TR></TABLE>
1- which b20 did you get? b20b or b20z?
2- if you need an ls skunk2 manifold i have one that i used on my b20, 200 picked up!
from my own experience, a non vtec b20 is lots of fun! specially since you'll be using a gsr tranny, and not an ls one. unless you do springs and retainers, you'll need to stop revving at 7K rpms. i tell you this because i did 6 valve adjustments, in less than two months! the valve train in the b20, will only handle about 7.2K rpms before the valves start to float! with the boltons you have listed, you'll love the way the b20 will drive. specially using the 50 shot(it will handle a 75 with no problems) you'll love it!
Old Jul 28, 2003 | 06:03 AM
C ronic's Avatar
Thanks all.
Smokey, that's an answer I was lookin for. I plan to use the LS's stock rev limit, this isn't gonna be a racer, I already had a 26psi SOHC motor in before this one (Which consequently has a hole in it). Fun motors SOHCs. I picked up a turbo 280, which, once the Civic is back up, is gonna be my weekend car.
Now I guess I use a B16 linkage, but which throttle cable do I use?
Old Jul 28, 2003 | 08:55 AM
nahledge 7's Avatar
C ronic and Smokey2.0 need to get together and invite me to the party, nahm sayin?
Old Jul 28, 2003 | 07:15 PM
smokey2.0's Avatar
Default Re: (nahledge 7)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nahledge 7 &raquo;</TD></TR><TR><TD CLASS="quote">C ronic and Smokey2.0 need to get together and invite me to the party, nahm sayin?</TD></TR></TABLE>
well, i'll be in orlando in october for the annual crx meet! if you guys wanna come down for that, we can meet there. check out each others rides, and share some ideas
Old Jul 29, 2003 | 05:43 AM
DevinW's Avatar
Check out this link for my parts list: http://www.revinrex.com/b20beast.php
Also, if you get a B20Z or JDM B20B, you'll be in the area of 140 hp/130 ft-lbs torque at the wheels, with all the bolt-ons.
Old Jul 29, 2003 | 07:26 AM
b20_ed's Avatar
Default Re: B20 swap, tips/info? (DevinW)
oh yes, the b20 is monstrous fun! I too have a gsr tranny, and damn this thing pulls like a rape ape!
b20bullet
Nov 4, 2010 09:03 PM
ATrin
Mar 10, 2008 05:37 AM
AZ90DATEG
Dec 29, 2006 06:05 PM
feligon18
May 30, 2006 01:47 PM
jeekE_
12
Jul 27, 2002 09:31 AM
