D series turbo kit F/S
I've been debating on the turbo project for the pass couple days and I want to test the waters. Shoot me your offers, as a package or to part. Don't ask me how much I want because I asked first for your offer. Here is exactly with it comes with:
-Sard BOV w/ charge pipe that can be cutted
-IHI RHB5 VJ11 turbo w/ no shaftplay milage unknown but very clean
comes with internal wastegate and down pipe w/ 02 housing. The exhaust port has NO cracks and is very clean, and should spool very fast
-HF manifold with heat shield and O2 sensor
-HUGE FMIC: 28x8x3.5 spearco style endtanks
-Autometer Ultra lite gauges NEW never installed but mounted:
-EGT w/o probe
-Oil pressure w/ electric sender
-Boost in PSI
-Volts
-DSM 450 blue top injectors
-B&M universal FPR
-TSUDO turbo mufller with 3'' tip and 2.5'' inlet
All you need to make it work is mount the turbo on the manifold, get some fittings and lines. Make some charge pipes and modify the downpipe to your car and run the rest of the wiring. Will fit all D15/D16 motors and even the ZC DOHC/SOHC motor with minor modification.
oh yeah, underneath the bumper is still another 2 inches of intercooler to expose...
Modified by sNoOziN' EF8 at 2:53 AM 7/25/2003
-EGT w/o probe
-Boost in PSI
-Volts
-B&M universal FPR
pics are on the way when i can get ahold of somebody that will let me borrow their digi cam. btw, the motor isn't for sale, just the turbo setup
EMwUnDuH
Jul 5, 2006 09:03 PM
