zc whoas!!!!!!!!!
Old Jul 24, 2003 | 10:58 PM
Slo-SoL's Avatar
Default zc whoas!!!!!!!!!
alright guys someone in here has to know that the zc is a pain. if not the distributor than something else. anyways. my zc it won't do anything but crank it won't turn over. i changed the fuel pump, i changed the main relay. i have my stock 91 si ecu and it gives me a code 0 and a 89 integra ecu gives me a code 0. i've changed the ignitor. i dont' know what else it could be. one time it backfired, and it gives a spark. it didn't but i fixed that. i forgot a ground. i want this car to run. i've got a lot of parts to go on it. and won't till it at least runs. i did have to hardwire my distributor. but that seems cool. i've checked it 4 times. tomorrow i'm stripping a 89 integra and grabbing everything i might need hopefully something helps. later
Old Jul 24, 2003 | 11:03 PM
FourthGenHatch's Avatar
Default Re: zc whoas!!!!!!!!! (Slo-SoL)
What the hell is code 0? The ECU flashes uhh... 0 times?? That should mean your car is ok.
You have hooked up all your grounds right, including the thermostat one.
Have you tried swapping the 2 white wires on the distributor and seeing what happens?
Old Jul 24, 2003 | 11:32 PM
Vinceg99's Avatar
Default Re: zc whoas!!!!!!!!! (FourthGenHatch)
Are you meaning by a code 0 that it just stays lit all the time?? If so your ECU is shot.
Old Jul 25, 2003 | 04:59 AM
DJ_SaNdOz's Avatar
Default Re: zc whoas!!!!!!!!! (Vinceg99)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Vinceg99 &raquo;</TD></TR><TR><TD CLASS="quote">Are you meaning by a code 0 that it just stays lit all the time?? If so your ECU is shot.</TD></TR></TABLE>
Old Jul 25, 2003 | 08:58 AM
Stupid Ass's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by FourthGenHatch &raquo;</TD></TR><TR><TD CLASS="quote">What the hell is code 0? The ECU flashes uhh... 0 times?? That should mean your car is ok.
Have you tried swapping the 2 white wires on the distributor and seeing what happens?</TD></TR></TABLE>
Uh.... ECU doesn't flash... ECU go bye bye...
Old Jul 25, 2003 | 09:05 AM
CRXRageD's Avatar
Default Re: zc whoas!!!!!!!!! (MooreVTEC)
Yup, one bright red LED and it means your hosed.
Old Jul 25, 2003 | 07:00 PM
Slo-SoL's Avatar
Default Re: zc whoas!!!!!!!!! (CRXRageD)
yeah i know that. the solid red is suppoisedly a code 0 at least thats what the guy at the dealership told me. but i think it's a little strange both of my ecus do that. so i guess i was hoping. oh and that integra i was gonna get some parts off of turned out to be a 87 so no luck.
Old Jul 25, 2003 | 07:01 PM
Slo-SoL's Avatar
yeah i've tried swapping the white wires. and i've checked all my grounds.
Marko Ef gdl
Oct 27, 2016 09:41 PM
catamanchuk
Apr 12, 2013 07:18 PM
Vagitarian
Jul 14, 2012 05:06 PM
stickman78114
Feb 25, 2010 04:23 PM
balistic CRX
Feb 9, 2002 06:03 AM
