Gapping of spark plugs
I'm not sure if your running standard core plugs or plats. But I will tell you that I run standard core NGK's in my R. If you like, try these NGK's... stock# 1273. They are one heat range cooler plug than stock & they really help cut down the risk of detonation. 7 bucks is not bad for a set of plugs!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B2FiNiTY »</TD></TR><TR><TD CLASS="quote">Stock is 1.1mm Heat range of 6.</TD></TR></TABLE>My mistake, GSR is the only B series with 1.3, all others are 1.1 i believe.
