Best way to remove spoiler???
Old Jul 24, 2003 | 08:39 PM
Chris_k604's Avatar
Default Best way to remove spoiler???
When trying to remove my spoiler, I noticed adhesive between the spoiler and the top of my trunk. What is the best way to get the spoiler off without ruining the paint on the trunk?
Thanks
Chris
Old Jul 24, 2003 | 08:51 PM
1GreyTeg's Avatar
Default Re: Best way to remove spoiler??? (Chris_k604)
fishing line or dental floss, then remove the adhesive with something like afta
just be sure to apply a new coat of wax afterwards.
Old Jul 24, 2003 | 09:31 PM
98cwtypeR's Avatar
Default Re: Best way to remove spoiler??? (1GreyTeg)
i did mine with dental floss....but make sure you have a lot of it, cause the line breaks very easily.
Old Jul 24, 2003 | 10:21 PM
nEoMuGen's Avatar
Default Re: Best way to remove spoiler??? (98cwtypeR)
10 lbs fishing line does the work.
Old Jul 25, 2003 | 12:16 PM
Cosworth's Avatar
Also, heat up the adhesive by using a hairdryer. Just use enough to heat it up a bit. Don't be blasting it on the paint.
Old Jul 25, 2003 | 12:20 PM
RagingAngel's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Chris_k604 &raquo;</TD></TR><TR><TD CLASS="quote">When trying to remove my spoiler, I noticed adhesive between the spoiler and the top of my trunk. What is the best way to get the spoiler off without ruining the paint on the trunk?
Thanks
Chris </TD></TR></TABLE>
Park the car in a heatbag location known for thieves....make sure you wash and wax the car before so it's nice and eye catching.
Go get some coffee and come back ..within 20mins or so, VOILA!! Spoiler is off!....sometimes the whole car goes missing too!!
But in all seriousness, dental floss works good along with a hairdryer for the adhesive....
Old Jul 25, 2003 | 03:46 PM
Rob :190:'s Avatar
Default Re: Best way to remove spoiler??? (RagingAngel)
park your car at NC State university for a night.......
splat's ITR
Old Jul 25, 2003 | 03:51 PM
Splat's Avatar
Collector-o-Guns and Drinker
Default Re: Best way to remove spoiler??? (Rob :190:)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Rob :190: &raquo;</TD></TR><TR><TD CLASS="quote">park your car at NC State university for a night.......</TD></TR></TABLE>
Or at an apartment complex in one of the richer parts of Cary, which is where the above incident happened
If you live in the Triangle, and come across any rich ******* kids from Cary HS that live in Lochmere, you have my permission to beat the living **** out of them.
Old Jul 25, 2003 | 07:08 PM
(__________)'s Avatar
Default Re: Best way to remove spoiler??? (Splat)
I used a hair dryer and fishing line, it came right off
Old Jul 26, 2003 | 01:22 AM
Cyber ITR's Avatar
Default Re: Best way to remove spoiler??? (steves98itr247)
how long did it take u guys average to take the spoiler off using dental floss and heatgun ??
Old Jul 27, 2003 | 06:29 PM
tinkfist's Avatar
Default Re: Best way to remove spoiler??? (Day Walker)
what are you all doing with the holes that are left underneath?
Old Jul 27, 2003 | 06:34 PM
TypeR 599's Avatar
Default Re: Best way to remove spoiler??? (tinkfist)
the first time i took mine off, i just took out the 4 bolts, then pulled back on the wing with moderate force. it came off
Old Jul 27, 2003 | 08:16 PM
HondaGuRu's Avatar
splat's ITR </TD></TR></TABLE>
Thats how mine came off. stupid *** holes. **** my ride up.
Old Jul 27, 2003 | 08:26 PM
Rob :190:'s Avatar
random plugs from my garage and touch up paint
Tip: when you put in the plugs, use some silicone or something similar to seal the holes, otherwise water will seep down into your tail lights
rob- water tails equipped. live and learn
Old Jul 27, 2003 | 08:30 PM
Bob#455's Avatar
What you want to do is tie a string to your spoiler and then tie the other end to your front door. Remove the bolts, then slam your front door shut (or if it opens inwards, you'll have to kick it open). The wing should come right off!
P.S. In case you couldn't tell I was kidding, the dental floss/fishing line suggestions above are the way to go.
Old Jul 28, 2003 | 11:51 PM
Aoi-Zip's Avatar
the fishing line method should work..
but be sure to have a friend or someone to hold on to the spoiler while you do it... you don't want it to fall off to the ground....
Aoi-Zip: who's seen that happen before...
Old Jul 29, 2003 | 02:27 AM
b18c-rDC2's Avatar
Default Re: Best way to remove spoiler??? (Aoi-Zip)
that pic is just another reason to go wingless..save yourself the headache
remove your wing before someone else does it for you
Old Jul 29, 2003 | 05:31 AM
NINJA's Avatar
Default Re: Best way to remove spoiler??? (b18c-rDC2)
I used dental floss, than good old Windex
Old Jul 29, 2003 | 07:18 AM
black sohc civic's Avatar
what becomes the 3rd brake light with the spoiler off? legally?
Old Jul 29, 2003 | 07:20 AM
Rob :190:'s Avatar
Default Re: Best way to remove spoiler??? (black sohc civic)
Hype Rs have no third brake light on the wing
Old Jul 29, 2003 | 10:25 AM
1GreyTeg's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by black sohc civic &raquo;</TD></TR><TR><TD CLASS="quote">what becomes the 3rd brake light with the spoiler off? legally?</TD></TR></TABLE>
NeOn Or GlOwStIx Yo!
Old Jul 29, 2003 | 03:06 PM
lustedp's Avatar
hahahahahaha
lilbastrd
Honda S2000
57
Mar 8, 2005 09:16 PM
azian21485
Feb 17, 2005 03:53 AM
FoxRiderH22A
Dec 12, 2003 09:59 AM
ocbeta
Apr 26, 2002 02:44 PM
