Oil cooler lines leaking??
Old Jul 24, 2003 | 08:26 PM
blykins's Avatar
Banned
Default Oil cooler lines leaking??
I keep having oil dripping down onto my header and creating smoke from the header being hot. Its embarassing. I've tighted the filter down as tight as i can get it and the bottom of it has oil on it. My next guess of the leak is from the oil cooler or oil pressure sensor. If the leak is from the oil cooler, when i take the black hoses off, will oil shoot everywhere, or do i have to drain teh engine like im doing an oil change and refill it.
Thx.
Old Jul 24, 2003 | 09:02 PM
ragejed's Avatar
Default Re: Oil cooler lines leaking?? (blykins)
Coolant will come out from the oil cooler hoses.
EDITED
Modified by ragejed at 8:13 AM 7/25/2003
Old Jul 24, 2003 | 10:33 PM
IN VTEC's Avatar
Pair of black hoses are coolant, not oil.
Regardless of being empty or not, coolant and oil will drip down when you remove the hoses and oil cooler. It's just a matter of how much. If you drain the coolant in the block below the level of the oil cooler, it won't empty out as much coolant. You won't need to drain the oil pan. Just let it sit for a while after removing the oil filter to let the oil cooler empty out.
I'd check the oil cooler flange where the filter sits on for debris and clean it first. Doubling up gaskets or debris can inhibit oil filer gasket sealing. Unlikely that it's double-gasketed...would have already sprung a loud leak.
Old Jul 25, 2003 | 07:13 AM
ragejed's Avatar
Default Re: Oil cooler lines leaking?? (IN VTEC)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by IN VTEC &raquo;</TD></TR><TR><TD CLASS="quote">Pair of black hoses are coolant, not oil.
I'd check the oil cooler flange where the filter sits on for debris and clean it first. Doubling up gaskets or debris can inhibit oil filer gasket sealing. Unlikely that it's double-gasketed...would have already sprung a loud leak.</TD></TR></TABLE>
Woops, coolant, your right...was too late last nite. Stupid me Should have know...I put one on my 98 gsr
Old Jul 25, 2003 | 07:41 AM
Trey's Avatar
25 Year Member
Default Re: Oil cooler lines leaking?? (ragejed)
I think I shaved off 5 years of my life riding behind you last night.
Old Jul 25, 2003 | 09:31 AM
blykins's Avatar
Banned
Default Re: Oil cooler lines leaking?? (Trey)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Trey &raquo;</TD></TR><TR><TD CLASS="quote">I think I shaved off 5 years of my life riding behind you last night.
At one point i literally could not see your headlights b/c of the smoke.
Old Jul 25, 2003 | 09:59 AM
blykins's Avatar
Banned
Could it be the oil pressure sensor leaking somehow? Can it even leak? I'm a NooB.
Sweetsystem
Mar 24, 2013 08:08 PM
Hanmin
11
Apr 25, 2009 09:18 PM
welfarepc
Jan 10, 2007 10:26 AM
