stuttering problem...
Old Jul 24, 2003 | 08:18 PM
Yoshi02Si's Avatar
Default stuttering problem...
ok.. im driving after stopping at the stop sign...i go and accelerate driving like normal...in second and third gear as it accelerates i feel the car kinda stutter and when i look at the rpm i notice it kinda stutters slightly as well... the stutttering usually occurs around 2-4 rpm...wuts goin on here??? somebody help my please!!!
Old Jul 25, 2003 | 05:36 AM
taikahn's Avatar
Default Re: stuttering problem... (Yoshi02Si)
get hondata... problem will go away.... its inherent in the lower power k series ....
hondata.com
Old Jul 25, 2003 | 10:29 AM
BlairSpeed's Avatar
I notice this too on my Si. I know that at 2200rpm, the vtec is engaged but I dont understand while the car stutters. It seems to only do this when I lug the car in a gear and then step on it. When I drive it hard, there is no stuttering.
Old Jul 25, 2003 | 05:14 PM
migs's Avatar
Default Re: (BlairSpeed)
I asked this question too, and found out that its a glitch on the way the car is built.
Old Jul 26, 2003 | 11:35 AM
the JigGa mAn's Avatar
Default Re: (Migs)
ive never had this problem with my si...
Old Jul 28, 2003 | 11:56 AM
delSolLS's Avatar
Stuttering, stumble whatever you call it, shouldn't be "inherent in all EP3's". If it's a glitch in how the car was built, should there be a recall?
Is Honda working on a fix for this problem? Is it ECU related?
Was planning on taking a test drive next week, want to replace my 93 del Sol Si with the EP3 as a daily driver. Pricing on the 2003 Si seems pretty good right now.
What is up with the stutter problem? Why don't more people complain about this fault? Even with the price being right, a engineering problem or ECU problem should be addressed by Honda, shouldn't it?
Old Jul 28, 2003 | 12:25 PM
Willard's Avatar
https://honda-tech.com/zerothread?id=529653
Old Jul 28, 2003 | 12:34 PM
delSolLS's Avatar
Default Re: stuttering problem... (Willard)
I read that thread as well. It provides a couple of possible reasons, but no way to fix the problem.
Is Honda looking in to a fix?
Old Jul 28, 2003 | 03:15 PM
CivicSI03's Avatar
Default Re: (the JigGa mAn)
I Have a 03 Civic Si Hatch No Problems no stuttering like yours is doing... That sounds real bad!
Old Jul 28, 2003 | 03:55 PM
Todd00's Avatar
I said I don't want a title!
Default Re: stuttering problem... (taikahn)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by taikahn &raquo;</TD></TR><TR><TD CLASS="quote">get hondata... problem will go away.... its inherent in the lower power k series ....
hondata.com
I have hondata and the problem did not go away. It is much more pronounced on hot days. When the temp is cooler I have not noticed the problem as bad.
Old Jul 29, 2003 | 07:06 AM
CivicSI03's Avatar
Default Re: stuttering problem... (Todd00)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Todd00 &raquo;</TD></TR><TR><TD CLASS="quote">
I have hondata and the problem did not go away. It is much more pronounced on hot days. When the temp is cooler I have not noticed the problem as bad.</TD></TR></TABLE>
I dont think the outside temp or engine temp would have to do anything with it... I live in Tx its been arround 100 here and I have not had any stuttering problems!
Old Jul 29, 2003 | 11:34 AM
Aquaman's Avatar
Default Re: stuttering problem... (delSolLS)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by delSolLS &raquo;</TD></TR><TR><TD CLASS="quote">
Why don't more people complain about this fault? </TD></TR></TABLE>
Because its really not that big of deal. It only happens once in a while when the engine is cold. After it warms up, it goes away.
Old Jul 29, 2003 | 02:05 PM
Todd00's Avatar
Default Re: stuttering problem... (CivicSI03)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CivicSI03 &raquo;</TD></TR><TR><TD CLASS="quote">
I dont think the outside temp or engine temp would have to do anything with it... I live in Tx its been arround 100 here and I have not had any stuttering problems!</TD></TR></TABLE>
What modifications do you have? A stock EP3 does not do it nearly as bad as a modified EP3. At least that's what I have experienced. And on hot days, the car does it worse.
Again though, it's only when you are putting around from 1st to 2nd and you decide to give 2nd a little more gas when you shift.
Old Jul 29, 2003 | 02:26 PM
jerky's Avatar
check your oil? i dunno that seems to solve a couple of "stuttering" problems. our car eats oil like mad. i check it frequently.
prelude_93vtec
Oct 4, 2007 04:29 AM
Devious951
Jun 5, 2007 03:28 PM
MagnusNirell
Jul 8, 2005 11:09 AM
YellowSpeed
Jul 16, 2002 11:21 PM
