did Spoon Sports make a vtec controller??
Old Jul 24, 2003 | 06:29 PM
SPOON 1's Avatar
Default did Spoon Sports make a vtec controller??
hey I was woundering if spoon made a vtec controller for the dc2 I see they made one for the DA and the civics was woundering if they made one for the dc2 and if anyone has used it
Old Jul 24, 2003 | 06:33 PM
SlapSmak's Avatar
Default Re: did Spoon Sports make a vtec controller?? (SPOON 1)
they only make one type as far as i have seen, but it works with any vtec based engine, you just have to wire it according to the ecu harness. It is very pricey considering it has no fuel tuning ability.
Old Jul 24, 2003 | 06:36 PM
SPOON 1's Avatar
hmm so its really not worth it because I found one that they claim is for the dc2 it has a description on the box says dc2/8 I just never thought they made one for our cars..so it adjust the vtec but whats the point if you can adjust the fuel then
Old Jul 24, 2003 | 06:41 PM
B2FiNiTY's Avatar
Default Re: (SPOON 1)
It's so basic that it really isn't worth it unless you wanna show it off.
Old Jul 24, 2003 | 11:36 PM
MiraiZ's Avatar
Default Re: (B2FiNiTY)
VTEC controllers are cheap....don't need to get the spoon one to be special
Old Jul 25, 2003 | 12:20 AM
Kengs's Avatar
Default Re: (MiraiZ)
Old Jul 25, 2003 | 05:01 AM
SPOON 1's Avatar
so i guess I should just stick with my V-AFC instead
Old Jul 25, 2003 | 07:07 AM
Tweakmeister's Avatar
yeah,
and the Spoon is only OBDi compliant (although i don't know why it wouldn't work with obdii)
Old Jul 26, 2003 | 11:29 AM
SPOON 1's Avatar
hmm I wounder if spoon meant to use the controller in conjuction with there ecu...since the controller doesnt control the fuel curves but jus the VTEC you would need to run there ecu that does modify the fuel curves and air ratio
Old Jul 26, 2003 | 11:39 AM
JDC2's Avatar
definetly not worth its value with the other brands out there for less.
FakeJDMEF8
Jul 27, 2005 08:40 PM
spoon92hatch
Oct 17, 2003 07:49 AM
SPOON 1
Aug 16, 2003 02:20 PM
IntegraT
Nov 12, 2001 11:23 AM
