very poor mileage
Old Jul 24, 2003 | 03:45 PM
YNOT's Avatar
Default very poor mileage
i only getting about 20mpg while doing 50/50 (highway/city) and shifting no higher than 35k.
here's what i've done trying to improve but see no good results:
4 wheel alignment and balance
5w30 mobil 1
no using air-conditioning
performed a 90k service at acura 6 months ago... car only has 80k
i drive in the bay area so climate is always around the 70's or lower.
been using cheveron 91 or shell 91
car only has aem cai and dc 4-2-1 headers
any clue on how i can improve my mileage? do i need new plugs or wires? i replace my platium ones in 2000... the car is a 96 gsr. thanks!
Old Jul 24, 2003 | 03:50 PM
P1mpSlap's Avatar
Default Re: very poor mileage (YNOT)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by YNOT &raquo;</TD></TR><TR><TD CLASS="quote">shifting no higher than 35k.
I think we found the problem
Old Jul 24, 2003 | 04:32 PM
RayB's Avatar
Do you have a check engine light on? Maybe MAP sensor, air/fuel (4-wire o2) sensor, or leaking vacuum lines...those are a few things you could try testing and/or checking out...good luck...
Old Jul 24, 2003 | 05:08 PM
EL Vap133's Avatar
Check your air filter to see if it's drity, check your plugs and wires, check your oil to see if it's black, etc... Oh and stop shifting at 35k....
Old Jul 24, 2003 | 06:13 PM
thrty8street's Avatar
Default Re: very poor mileage (Vap133)
35 thousand? GOD damn dawg. your engine must be HURT. that must be some ecu huh?
Old Jul 24, 2003 | 06:15 PM
VTECorona's Avatar
Default Re: very poor mileage (thrty8street)
Check ur plugs, if they are dark then you are running rich and using more fuel than you should be. Then you can go from there
Old Jul 24, 2003 | 06:17 PM
THE94GSR's Avatar
check the fuel filter.
Old Jul 24, 2003 | 06:34 PM
integraL's Avatar
Default Re: very poor mileage (THE94GSR)
my oil color is like chocolate...thats normal right? im getting about 23 mpg while shifting at 3k. i'll hit 5-6k rpms once in a while.
Old Jul 24, 2003 | 06:45 PM
juniordc2's Avatar
Default Re: very poor mileage (integraL)
i goto 4000rpm in 1st, and 2nd, then shift into 3rd for a few rpm then 5th and cruise at 60kph (40mph) on city roads where it is limited.. i get 32mpg using a/c and with some spirited runs.. check the airfilter and maybe the o2 sensor. btw, i got a 94 gsr with about 95k miles on it or so.
Old Jul 24, 2003 | 09:14 PM
InTeGrA B18b1's Avatar
Learn to drive. dont gas to much or change your o2 sensor. change your spark plugs etc
Old Jul 24, 2003 | 09:19 PM
xteg95's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by integraL &raquo;</TD></TR><TR><TD CLASS="quote">my oil color is like chocolate...thats normal right? im getting about 23 mpg while shifting at 3k. i'll hit 5-6k rpms once in a while.</TD></TR></TABLE>
when youre oil is dark...it means its dirty and needs to be changed
Old Jul 24, 2003 | 09:27 PM
Heisdan's Avatar
Default Re: very poor mileage (InTeGrA B18b1)
<FONT COLOR="red">"Learn to drive" Inappropriate !!!!</FONT> Lol
My suggestion (for myself too .. cause I can't get better than 25 mpg no matter what I do) is fuel filter and new air filter.. I have a shortram ram on my GSR and I need to get a cai .. so I'm just waiting until i get hte color air setup before I get a new filter.. (comptech icebox w/ diy corner intake.. love it)
Old Jul 24, 2003 | 09:31 PM
riceball777's Avatar
i get about 21-23 mpg and if i drive a lot of high way i might get 25mpg
i can never *** 25mpg
Old Jul 24, 2003 | 09:48 PM
Aaron M's Avatar
Default Re: very poor mileage (riceball777)
Plugs...
I have 15k on my copper plugs and I'm noticing a decrease in gas mileage.
Get new plugs
Old Jul 25, 2003 | 07:58 AM
YNOT's Avatar
Default Re: very poor mileage (SilverB18C1)
thanks for all replies...
i'll check my plugs and lines... (should my platinum plugs last me 4 years?)
fyi, i changed my fuel filter when doing the 90k maintenance and cleaned the air filter about 3 months ago. on a side note... i get only about 15mpg when i shift in the vtec range.
Old Jul 25, 2003 | 08:37 AM
detaude's Avatar
I get 24 in city and 32 on highway, the trick is to always try to coast in neutral and avoid using the gas and brake pedal. Maker sure your injectors are clean too.
Old Jul 25, 2003 | 09:07 AM
ArizSun21's Avatar
From: Do I look like Michael Bolton from Office Space,, MD, USA
Default Re: very poor mileage (detaude)
I am getting 25 - 32 mpg depending on how much I am in vtec!!
Old Jul 25, 2003 | 09:11 AM
mickey513's Avatar
I have the same freaking problem on my 94gsr and my motor is all stock, never had anything done to it. I done the full-tune up not too long ago with all OEM parts and it's hasn't help much.
Change the spark plugs, sprak plug wires, fuel filter, air filter, dis. cap & rotor and still no good. I am average about 20mpg going 50/50 city, highway and shift about 3 to 3.5k.
Old Jul 25, 2003 | 09:22 AM
mugenracer's Avatar
I get 26-30mpg depending on conditions, but its usually around the 28mpg mark with 50/50 combined city/highway driving
Old Jul 25, 2003 | 10:46 AM
Xumarius's Avatar
only one person thought about their fuel injection cleaning. Bro My fuel injection was so bad that I was getting 11 miles per gallon! I would suggest that. If it aint that, then your doing something wrong.
Old Jul 25, 2003 | 10:50 AM
romeo619romeo's Avatar
Default Re: very poor mileage (Xumarius)
go turbo .. yoour mpg will go up
Old Jul 28, 2003 | 10:09 AM
YNOT's Avatar
what kind/brand of fuel injector cleaner fluid do u guys recommend? STP? thanks...
Old Jul 28, 2003 | 10:27 AM
Aaron M's Avatar
what kind/brand of fuel injector cleaner fluid do u guys recommend? STP? thanks...</TD></TR></TABLE>
Chevron w/Techron
Old Jul 28, 2003 | 10:46 AM
TEXN3's Avatar
you don't need a fuel injector cleaner if you use a high quality gasoline, such as chevron(with techron additive). that is not very good mileage though. i get about 24mpg in city and 32 on the highway...and that is with an auto and not always taking it easy.
make sure your cat. hasn't collapsed. happened on a car of ours and with so much backpressure we got very dismal mileage.
Old Jul 28, 2003 | 10:54 AM
ee-gsr's Avatar
Default Re: very poor mileage (texnteg)
i read this once but no one mentioned it above. did u try reseting your ECU? some guy did this once and it solved his mpg problem. good luck.
