2001 b20Z , is it OBD2? Will the 01 dizzy work? Someone told me that the hood will clear the manifol
Old Jul 24, 2003 | 11:12 AM
Nikos's Avatar
Default 2001 b20Z , is it OBD2? Will the 01 dizzy work? Someone told me that the hood will clear the manifol
I need to know
Is the 2001 b20z, obd2? What dizzy should be used in an 92-95 EG?
I read that the b20z flat manifold can fit in a eg. Is this true? I know it should be changed for better flow in high RPMs but will it fit?
Modified by Nikos at 10:37 PM 7/24/2003
Old Jul 24, 2003 | 11:48 AM
Newman's Avatar
New User
Default Re: 2001 b20Z , is it OBD2? Will the 01 dizzy work? Someone told me that the hood will clear the man
2001 B20Z motor is OBD-2 ver 2. Any LS distributor will bolt onto the head, as it's still an LS head. You can use any 92-95 Integra distributor and it'll plug right into your 92-95 Civic. Otherwise, repin your 2001 distributor to the OBD-1 plugs (off of your old stock motor) and use that distributor.... same electronics.
As for the manifolds, if you're talking about the chamber cover on the LS manifold, yes it'll clear the hood (someone posted pictures of it a few weeks ago... search for it) but if you're talking about the giraffe style manifold, no it won't fit under the hood.
Old Jul 24, 2003 | 11:55 AM
Nikos's Avatar
Will this fit in an EG?
We are going to use a OBD2 harness. So which dizzy is the best?
Old Jul 24, 2003 | 12:06 PM
Newman's Avatar
New User
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Nikos &raquo;</TD></TR><TR><TD CLASS="quote">Will this fit in an EG?
We are going to use a OBD2 harness. So which dizzy is the best?</TD></TR></TABLE>
Just like I already said..... As for the manifolds, if you're talking about the chamber cover on the LS manifold, yes it'll clear the hood (someone posted pictures of it a few weeks ago... search for it) but if you're talking about the giraffe style manifold, no it won't fit under the hood.
Old Jul 24, 2003 | 06:29 PM
Nikos's Avatar
What kind of flywheel can I use? Will a Gs-r flywheel work?
Also can stock A/C be retained?
Old Jul 24, 2003 | 07:27 PM
thid92's Avatar
can I haz?
gsr flywheel will be fine. A/C use a B16 A/C bracket from a del sol
Old Jul 27, 2003 | 05:19 AM
Nikos's Avatar
Default Re: (thid92)
Only wiring that will be needed is going to be the knock sensor and the 4 wire O2 sensor convert? With a 94-95 LS ECU is that all?
Can the ECU get chipped to eliminate the knock sensor wiring?
Old Jul 27, 2003 | 05:39 AM
VTECVillain's Avatar
Default Re: (Nikos)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Nikos &raquo;</TD></TR><TR><TD CLASS="quote">Only wiring that will be needed is going to be the knock sensor and the 4 wire O2 sensor convert? With a 94-95 LS ECU is that all?
Can the ECU get chipped to eliminate the knock sensor wiring?</TD></TR></TABLE>
There is no knock sensor circuit in the nonVTEC ECU's. You only need to convert to a 4 wire O2 if the car is a VX or CX. All other EG models already have 4 wire O2's.
Old Jul 27, 2003 | 06:11 AM
eg6ajk's Avatar
yes, OBDII 99-01 style with lacking tach pick up on the dizzy you can use 92-5 LS/b18a/b dizzy for easy bolt on affair.
yes torque chamber clears just fine in a EG.
GODofWARREN
May 12, 2013 12:50 PM
Joacnel
Engine Management and Tuning
Apr 4, 2012 07:02 PM
DuongBros.
Dec 11, 2008 05:11 PM
nikkarocky
Apr 10, 2007 12:54 PM
Soled Out
Jan 15, 2003 03:50 PM
