Which rear differential oil to use in a s2000?
I've used the Mobil 1 and the Red Line oil (not the shock proof formula, just the regular gear oil). Couldn't tell the difference between the two when driving to be honest.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TurboB18C1 »</TD></TR><TR><TD CLASS="quote">
OEM Honda
there is no suitable "OEM" diff. fluid for the s2k. the only thats available is the VTM4 which is made for crvs,etc. i recommend castrol hypoid c gear oil 75w90/80w90.
OEM Honda
I highly recommend Swepco 201 gear lube. call it one of those little tricks handed over from the Porsche guys. runs approximately 30-40 bucks a gallon which will last through three changes.
haha what a helpful thread, everybody uses something different. i used the LE 1605 and no problems what so ever. same as the guy above me used but the newer version. its a rich dark red formula kind of weird but works. got it from here: http://ricks2k.com/products/le1605.php
im sure you can use any of the ones listed above, just give it a frequent fluid change...my .02
Amsoil 75w140 (I use 140 b/c the way that PuddyMod built the diff and it requires it for Road Racing. Amsoil has always worked for me. I also used the old LE1605 fluid from HTG.
MtnCRX
Apr 24, 2005 06:36 PM
wizzards581
Mar 4, 2003 09:41 PM
