suspension click?
i just got my ITR rear sway installed. now when i make hard left turns, i hear a clicking sound on the rear pass side. is it the sway? i looked it over and i don't see any parts missing or loose. i have no idea what this could be... unless it's the sway bar itself. and help would do.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lDarkCloudl »</TD></TR><TR><TD CLASS="quote">but it's in the rear</TD></TR></TABLE>
Do you have aftermarket springs? If so, they could just be coming unseated slightly when the load is taken off of them. For example, when you're making a hard left turn, you would hear a clicking from the right rear. I don't know why that wouldn't have been happening before the swaybar install, though.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by acuraholic »</TD></TR><TR><TD CLASS="quote">
I don't know why that wouldn't have been happening before the swaybar install, though.</TD></TR></TABLE>
Great reply. The sway bar would cause the spring to unsettle because of the force it is exerting.
If you study the effects of a sway bar, It may make sense.
High rate rear sway bars cause the INSIDE REAR tire to actually LIFT in hard cornering.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Chris »</TD></TR><TR><TD CLASS="quote">
High rate rear sway bars cause the INSIDE REAR tire to actually LIFT in hard cornering.</TD></TR></TABLE>
Makes sense as a sway bar is essentially a large spring. I was speaking from personal experience with the aforementioned problem, though. When I first installed my H&R sports, they would become slightly unseated in the manner in which I previously described. That's what I was referring to. Since my problem occured WITHOUT the aid of a rear sway, I simply stated that he could be having the same problem as me.
so should i get new springs or take them out and have them looked at??
Hairy Hudson
May 14, 2008 07:24 PM
