having trouble starting my car...
Old Jul 24, 2003 | 11:00 AM
SimbaDogg's Avatar
Default having trouble starting my car...
i dont know whats wrong w/ my car, maybe someone can help. when i try to start my car it doesn't wanna start, instead it just makes this high rate clicking sound. i thought it was coming from the inside fuse area, but when i popped the hook it sounds like its coming from there as well. if i pop the clutch, it'll start just fine...then after i let it run for about a minute, i can shut it off, and start it up again just be turning over the ignition. anyone know what this could be? i checked some of the starter signal fuse, and thats fine. any help?
by the way, dont know if this'll make a difference, but its w/ a first gen b16.
Old Jul 24, 2003 | 11:09 AM
FourthGenHatch's Avatar
Default Re: having trouble starting my car... (DAFeLUNG)
Your starter is dead.
Vinceg99's Avatar
Bad battery that isnt holding a charge. I would have said alternator (which it could still be) but you said it will run for a minute and then you can shut it off and start it with the ignition so I would assume that your battery is bad take it to a place and they can test both the battery and the alternator while its in your car.
Old Jul 24, 2003 | 11:52 AM
SimbaDogg's Avatar
my starter is fine, so is my battery and alternator. i just had the alternator replace a few months ago, it charges the battery fine. my car used to do this about 6 months ago, but the problem just went away. even when i jump my car, it wont start...it'll continue to make this clicking noise, so i know its not the battery. its not the alternator cuz the battery is fully charged. so what else could it be?
Old Jul 24, 2003 | 11:56 AM
Stupid Ass's Avatar
Default Re: (DAFeLUNG)
Ignition coil!
Old Jul 24, 2003 | 12:00 PM
SimbaDogg's Avatar
well...would it be the coil, if sometimes it starts up, and sometimes it doesn't. i mean, its almost like rolling the dice, some instances it will, some it wont.
Old Jul 24, 2003 | 12:05 PM
Vinceg99's Avatar
Possibly the ignition itself?? And just because you replaced the alternator a few months ago doesnt mean it couldnt have gone bad again. I replaced mine with one and that one was bad from the factory!!
Old Jul 24, 2003 | 12:19 PM
SimbaDogg's Avatar
the alternator isn't bad, trust me...the battery if charged to the capacity.
NiKKa NiKKy
Jun 30, 2022 09:59 PM
egtony
May 18, 2009 09:58 AM
rafiq7
Dec 14, 2004 07:46 AM
Moe
Nov 13, 2003 08:56 PM
ToneyTigre
Nov 16, 2001 05:59 AM
