kPa -> compression ratio?
Old Aug 4, 2001 | 11:28 AM
kahren's Avatar
Default kPa -> compression ratio?
i just ran a compresions check on a stock '91 crx si motor and the needle said 180 kPa anyone have any clues how i would convert that into compression ratio, i know that for stock its aeound 9.1
Old Aug 5, 2001 | 05:46 PM
Gasoline Fumes's Avatar
Default Re: kPa -> compression ratio? (kahren)
I hope it was PSI not kPa. 180 kPa would be only 26.1 PSI. I'm not sure exactly what the pressure should be, but 180 PSI sounds pretty good if all the cylinders are close. A service manual will have the sevice limits for compression tests.
Old Aug 5, 2001 | 06:00 PM
Tbone's Avatar
Default Re: kPa -> compression ratio? (Gasoline Fumes)
You cant convert it.
gc8dc95
Feb 16, 2009 04:29 PM
peakboosth22
Jun 20, 2006 08:55 AM
6E LUDE
Nov 10, 2005 05:38 AM
AL ASPIRATED
Aug 22, 2003 04:52 PM
