new oil pump w/out pulling timing belt???
Old Jul 23, 2003 | 08:27 PM
92TEGsrSC's Avatar
Default new oil pump w/out pulling timing belt???
I know helms book says to pulling the timing belt is necessary when changing the oil pump-- but has anybody done it without??? I'm kicking myself in the butt right now because earlier today I changed my timing belt and water pump-- everyone says that they get them done at the same time-- so that's what I did... Anyway, I also have a new oil pump to install, but didn't look to see if it was necessary to do with the timing belt off... Can anyone tell me that they've done it without pulling the timing belt??? PLEASE.. I don't wanna pull that belt off if I don't have to.
Thanks in Advance,
Zack
Old Jul 23, 2003 | 10:09 PM
fuccarlos's Avatar
um right you must pull the timing belt and the oil pan and take off your header and crankpulley no way around this install and it pretty messy
Old Jul 23, 2003 | 10:16 PM
4crx4me's Avatar
Default Re: (fuccarlos)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fuccarlos &raquo;</TD></TR><TR><TD CLASS="quote">um right you must pull the timing belt and the oil pan and take off your header and crankpulley no way around this install and it pretty messy</TD></TR></TABLE>
Yes, the crank goes thru the oil pump so there's NO WAY to get the oil pump off, without taking everything that's in front of it off first.
ie timing belt, water pump, pulley, tensioner, etc, etc.
jminthemachine
Dec 24, 2015 02:04 AM
VegasEg8
13
Sep 29, 2014 06:51 PM
uberEFtuner
Feb 9, 2010 07:10 AM
zhen_fai
Aug 25, 2007 07:39 AM
