White smoke coming out of the header..
White smoke is coming out of infront of the header below the engine. That happen when it hot when running all day to night. The smoke is visible at night, could not see the smoke at daytime. I have 81,000 mileage on the motor now..
Timing belt is replaced, radiator fluid replaced, oil pan replace, water pump, cam seal, headgasket replaced (doe it had to do with the radiator?)..
Any idea what cause this?
Doug
Doug
Since nobody answer my question, jezz. I found out what went wrong,
the cam shaft was bad which causing the oil to leak from the engine and hitting the header causing to develop a white smoke streaming out of the engine bay.
The cam shaft is old, replaced new cam shaft. Problem solved.
boostit2120
11
Jul 19, 2013 11:34 AM
KTeller8
Nov 11, 2002 02:16 PM
