94 VTEC - ABS system on and off
My ABS system goes on and off - somewhat randomly. Seems to be connected to outside temperature. Cannot get a trouble code out of it - service manual says if no code then a possible computer connection. If it is really cold out, ABS works and stays working while I drive. When it is medium temp outside, ABS light will come on and stay on and ABS is locked out. If it is really hot, or car has sat in hot sun, ABS light will go out and ABS is fine, until the next time I start it. Any ideas? Really don't want to take it to Honda dealer ($$$$), yet.
Correction... depending on the code. My ABS code was "main relay or ABS circuit"... yeah, helpful. The whole ABS's memory system is fubar'ed somehow and won't hold codes. The ABS system doesn't always work when cold, or when remote started, and they can't figure out why because no error codes are being stored.
Modified by rjr162 at 9:06 AM 7/24/2003
Guest
Posts: n/a
My ABS wasnt working because of a speed sensor.. well, this is what happened..
https://honda-tech.com/zerothread?id=568603
Just where is the ABS computer on this car? If I could find it, I would check the connections. ??? My Honda shop manual picture looks like it is behind the right panel in the back seat?
