About to bleed brakes, any tips before I do it?
Old Aug 4, 2001 | 01:24 AM
keys's Avatar
Default About to bleed brakes, any tips before I do it?
Anyone got any tips i should know about before I do it? Also, I heard of people whose brake master cylinders leaked after bleeding their brakes.... is this because they pushed the brake pedal too far while bleeding them? TIA
Old Aug 4, 2001 | 06:09 AM
smeister's Avatar
Default Re: About to bleed brakes, any tips before I do it? (keys)
Turn your key so your ABS is on when you bleed your brakes. HTH
Old Aug 4, 2001 | 09:52 AM
keithv's Avatar
I hear that is the cause to a leaky master cylinder...pushing the brake pedal too far. Try putting a small 2x4 under your brake pedal to keep you from going down too far.
HTH.
Old Aug 4, 2001 | 10:36 AM
keys's Avatar
Default Re: About to bleed brakes, any tips before I do it? (breaka_1_9)
alright kewl thanks, any more tips?
Old Aug 4, 2001 | 11:12 AM
Chris's Avatar
Driver front, passenger front, passenger rear, driver rear. Tap the caliper with a rubber mallet to loosen any stuck bubbles.
Bleed until you think you are done, then bleed some more!
Old Aug 4, 2001 | 11:18 AM
ILOVEGIRLS's Avatar
r u suppose to have your abs on?
Old Aug 4, 2001 | 11:24 AM
Chris's Avatar
Default Re: About to bleed brakes, any tips before I do it? (ILOVEGIRLS)
ABS is a completely seperate system. Do it with the engine and key OFF.
Old Aug 4, 2001 | 12:20 PM
GZR4DR's Avatar
Default Re: About to bleed brakes, any tips before I do it? (Chris)
If you spill fluid anywhere, make sure you clean it immediately. Brake fluid eats through paint.
deanh22a
Honda Civic (2001 - 2005)
Jan 29, 2017 05:32 AM
theineffable
Dec 17, 2010 05:57 AM
goldfinger93030
Sep 19, 2010 07:33 PM
InTheLBC20
Feb 14, 2009 05:26 AM
DA9 Integra
Jan 30, 2005 03:51 AM
