Torn trailing arm bushings
Old Jul 23, 2003 | 05:38 PM
Boosthead's Avatar
Default Torn trailing arm bushings
I bought my 93' Civic HB with under 70k miles. When I was rotating the tires, I noticed the trailing arm bushings are both torn. Is this common? The car was owned by a middle aged man who was the original owner and does not appear to be abused, but it's a possibility. Why do trailing arm bushings normally tear??
Old Jul 23, 2003 | 05:58 PM
KRiS1's Avatar
Default Re: Torn trailing arm bushings (Boosthead)
There was a TSB about them tearing. Mine need to be replaced too. Get the prothane replacements and don't go to the dealer! The dealer will charge around 600 for it. The prothanes are about 100 + 100 for install if you have a shop do it and 75 for an alignment which you will need after it is done.
Old Jul 23, 2003 | 06:09 PM
ninjaMONKEY
Guest
Posts: n/a
Default Re: Torn trailing arm bushings (POS Hatchback)
its easy to replace....
if you have access to a press
shops to charge way too much for about 2.5 minutes of work. My dad has one at work for me
akos512
Apr 14, 2019 09:38 AM
Telecatster
Suspension & Brakes
13
Mar 25, 2013 06:53 AM
rogue420
Jul 26, 2007 08:11 AM
Vitesse
Aug 1, 2006 08:12 AM
delguiner
Jan 18, 2005 02:05 PM
