im getting a power dip, whY!?
Old Jul 23, 2003 | 04:51 PM
jsk62's Avatar
Default im getting a power dip, whY!?
i took my car to get dyno tuned today and for some strange reason between 7-8k rpm i lose about 25 hp and then by 8400 rpm it comes back up to where it was right before the power loss.
does anyone have any idea why this is happening? i've had it dynoed before without any sort of problem like this. i also know its not a fluke because we dynoed it 5 times and everytime theres the same power loss at the same time.
i drive a 2k1 ITR and my mods include:
bolt ons (i/h/e)
mugen headgasket (raises 0.4 compression)
titanium retainers
i also did a compression test on it and the numbers all run about 210. anyone have any idea why this is happening?
Old Jul 23, 2003 | 05:06 PM
Phoenix_ITR's Avatar
Default Re: im getting a power dip, whY!? (jsk62)
possibly ignition related? did it feel at all like a "miss"?
jsk62's Avatar
Default Re: im getting a power dip, whY!? (delinquent)
hmm wats a "miss"?
Old Jul 23, 2003 | 07:24 PM
t's Avatar
t
What are the i/h/e? What you doing for fuel enrichment?
Old Jul 23, 2003 | 07:47 PM
jsk62's Avatar
Default Re: (t)
aem cold air
dc jdm type r
greddy sp exhaust
im using the greddy e-manage for tuning, and u can control fuel with that so im using the stock fuel regulator.
Old Jul 23, 2003 | 07:50 PM
vtec.dc2's Avatar
if this e-manage related - which i'm guessing is the problem.. either get someone that knows how to work with that piece.. or get a better managment system.. - bad or experimental tuning can mess things up..
Old Jul 23, 2003 | 07:58 PM
jsk62's Avatar
Default Re: im getting a power dip, whY!? (vtec.dc2)
its not e-manage related or ecu related. we dynoed it before we put the emanage in and had the same problem. we also tried using a obd-1 ecu and we still had the same problem. im thinking it might be mechanical....maybe valvetrain?
Old Jul 23, 2003 | 09:21 PM
t's Avatar
t
Default Re: (jsk62)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jsk62 &raquo;</TD></TR><TR><TD CLASS="quote">
dc jdm type r
Are you using a highflow cat? (Carsound, random, etc.) That would be your problem.
Old Jul 24, 2003 | 07:50 AM
Austin's Avatar
Post the plot with your A/F on it, still hard to diagnose.
Old Jul 24, 2003 | 10:01 AM
Brandon Clifton's Avatar
most B16 have a dip like that around 5400 due to resonance in the intake. Never seen one dip 25 hp though. usually B16 are around 7-10 hp
Old Jul 24, 2003 | 10:12 AM
jsk62's Avatar
Default Re: (t)
im running a test pipe, but that can't be the problem either. i've dynoed my car with it before with no such problem.
Old Jul 24, 2003 | 11:59 AM
sgT's Avatar
sgT
Default Re: (jsk62)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jsk62 &raquo;</TD></TR><TR><TD CLASS="quote">aim using the greddy e-manage for tuning, and u can control fuel with that so im using the stock fuel regulator.</TD></TR></TABLE>
Emanage DOES NOT control fuel.
It controls map sensor signal adjustment.
Not the same thing.
Old Jul 24, 2003 | 05:03 PM
jsk62's Avatar
Default Re: (sgT)
ok
Old Jul 25, 2003 | 01:37 AM
jsk62's Avatar
does anyone else have any suggestions or ideas as to why im having this problem? all i know is that its most likely a mechanical problem because we've tried running an obd-1 ecu with my car but that didn't solve the problem.
SilverBullet_01
Aug 15, 2008 02:38 PM
RSX_S
10
May 20, 2008 11:25 AM
Scorchin Civic
Feb 16, 2006 07:13 AM
EVLTEK
Nov 24, 2005 01:22 AM
DarknessJ
Aug 3, 2005 04:35 PM
