Max power with bolt-ons with stock B16 cams?
So far on my Si i have an AEM CAI, JDM 4-1, Apex N-1 cat-back, Exedy organic clutch, AEM fuel rail, B&M FPR, and Skunk2 IM. I am in the process of buying cam gears and a V-AFC and i was wondering if i get it dynoed what can i expect to put down with stock B16 internals? or is it even worth getting it tuned? Thanks
i have 140whp on my jdm b16 with 5 zigen header / stock air box / hks hiper exhaust / str cam gears / b&m fpr / and a chipped p28 to give you an idea
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by letholone »</TD></TR><TR><TD CLASS="quote">i wasnt guessing.
thats what i made.
p30 block
milled 40 thou.
skunk manifold
ericks 70mm TB
p30 cams.
jg header.</TD></TR></TABLE>
That was a pretty strong motor bro. Was that with Hondata?
thats what i made.
p30 block
milled 40 thou.
skunk manifold
ericks 70mm TB
p30 cams.
nope. some custom ECU program.
after that motor snapped a stock retainer in 1/2. i swapped over to a GSR head and ericks racing manifold with ctr cams. milled the head about 20 and ran the spoon head gasket to get me near the 11-1 area.
that made 190whp and 113 tq. at 9000
I baselined my car when I bought it. 1999 Civic Si with 195 across the board and bone stock. Baselined at 138whp and 101wtq.
I/TB/IM/H/TP/E/Pulleys(Ultra R's no a/c or p/s), 18 degree timing AND the kicker a stock P2T ECU throwing 2ndary o2 codes (for TP) and Idle System Control Failure codes. :highfive:
1st Run 144whp and 103wtq.
Break out the PGM Tester. Cleared the codes.
2nd Run 150.7whp @ 7,600rpm and 106.2wtq. @ 6,700rpm
I guess that's ok for slapping some bolt-on's on untuned.
When I'm done I'll break 200whp on a B16A2. That's my goal. That and a 12.99 in an Si N/A stock blocked car. I think that's pretty acheiveable.
151 sounds pretty nice Mr. Milano. Just think of what you could gain from moving to OBD1 and Hondata. You plan on running a big bore block right?
confusatron
Mar 25, 2006 12:23 AM
