DIY grounding kit questions..
im thinking about doing the grounding kit project on my 95 integra and was woundering where exactly do you ground the wires coming out from the battery...if a wire is going from the battery to the alernator would i connect the wire to a bolt holding the alernator in place? or would i acutally connect it to the ground wire going to alternator itself ....same goes for throttle body, IM...
as of now the only ground wire i see is one really thick wire going from the battery NEG to the body..
thanks
thanks
