water on the passenger side floor
i have a '99 integ and there is constantly a pool of water on the passenger side floor. I read another thread that it might be an a/c drain, but that was a guess. Anyone know whats going on?
it is more than likely what you think it is. If i remember right there is a drain tube under the car passenger side that can get clogged. you can run some wire through it and hopefully help unclog it.
This might not apply on your bodystyle teg, but the 2nd gen tegs have a problem with the clips that hold the cowl vent on and because of that it allows water to leak in onto the passenger floorboard whenever it rains...just an idea...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tommy b »</TD></TR><TR><TD CLASS="quote">i have a '99 integ and there is constantly a pool of water on the passenger side floor. I read another thread that it might be an a/c drain, but that was a guess. Anyone know whats going on? </TD></TR></TABLE>
Hope this is what you are looking for. https://honda-tech.com/zerothread?id=558709
thanks man. I saw you had answered the exact same question twice already. They didn't comeup in the search, i swear.
lol. Anyway, thanks for all the help and i will keep you all posted on how the cleaning went
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RayB »</TD></TR><TR><TD CLASS="quote">This might not apply on your bodystyle teg, but the 2nd gen tegs have a problem with the clips that hold the cowl vent on and because of that it allows water to leak in onto the passenger floorboard whenever it rains...just an idea...</TD></TR></TABLE>
I know this is also very true, so check out the cowl vents as well.
HTH
HTH
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 4crx4me »</TD></TR><TR><TD CLASS="quote">
HTH</TD></TR></TABLE>
I can third that. It happened in mine Integ for a long while during winter. Finally took it to a mechanic and they fixed that problem good. Really sucked though.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tilt »</TD></TR><TR><TD CLASS="quote">it is more than likely what you think it is. If i remember right there is a drain tube under the car passenger side that can get clogged. you can run some wire through it and hopefully help unclog it.</TD></TR></TABLE>
I had this same problem about 2 years ago, I did try a wire but used a air compressor for better results.
PatrickGSR94
Jan 30, 2005 02:38 PM
