on the nineth run it said caboom
Old Jul 23, 2003 | 09:58 AM
nobrakes's Avatar
Default on the nineth run it said caboom
any body know the life that a 95mm stroke block. non deck plate motor only 13to1 compression and onece i recived the motor it was hard to turn over by hand. motor was never misshifted or shifted higher than 8900 and it still manged to shoot a rod out the side on the nineth pass this happen to a racer in bristol tenn this past weekend any advice the motor was build by vince at golden eagle when i took it apart to see what happen besides the obvius found all the bearing clearence were set to tight. scored all the bearing mains and rods the thrust washer was also damaged i wonder who could be responsable for this just asking
Modified by nobrakes at 11:05 PM 7/23/2003
Old Jul 23, 2003 | 10:02 AM
J2turbo21's Avatar
Default Re: on the nineth run it said caboom (nobrakes)
Well im guessing if built right it should last awhile.
Old Jul 23, 2003 | 10:03 AM
advanracing62's Avatar
ummm... in english please... ???
Old Jul 23, 2003 | 10:36 AM
MaxBoost's Avatar
New User
Default Re: on the nineth run it said caboom (advanracing62)
No, if built properly with a deckplate and long rods, a 95mm crank/motor can have a really long life..
Old Jul 23, 2003 | 10:42 AM
TrboInteg's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nobrakes &raquo;</TD></TR><TR><TD CLASS="quote"> any body know the life that a 95mm stroke block should have is it normal for it to shoot a rod out the side on the nineth pass this happen to a racer in bristol tenn this past weekend any advice </TD></TR></TABLE>
Does anybody know punctuation or proper sentence structure?
Old Jul 23, 2003 | 11:47 AM
Fkned2003's Avatar
even if it's built right to begin with, it can still come apart in high horsepower race situation.Parts breakage isn't always due to install errors.
Old Jul 23, 2003 | 03:45 PM
Default Re: on the nineth run it said caboom (TrboInteg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TrboInteg &raquo;</TD></TR><TR><TD CLASS="quote">
Does anybody know punctuation or proper sentence structure?</TD></TR></TABLE>
agreed
cfwthb_94
Mar 18, 2008 07:55 PM
monalisa overdrive
Oct 20, 2004 10:54 AM
Nextelbuddy
Feb 15, 2004 09:43 PM
cleanEG
Feb 18, 2003 10:21 PM
allmotorhonda
Dec 27, 2002 09:21 PM
