greddy kit installed b16A 5th gen
Old Jul 23, 2003 | 09:55 AM
spooned out's Avatar
Default greddy kit installed b16A 5th gen
Car on jacks, turbo kit in, need info:
1. Whats the best source for vaccum hook-up? (which lines to use for the BOV and Actuator?) a diagram or pics would be appreciated.
2. Greddy turbo timer. Do civics have a Standard Ignition or w/2 Ignition wires (2on ignitons wires) and pictures would be helpfull.
3. Since i have a P30 ecu with a 99-00 greddy blue box and use the 5 generation wiring diagram is it the same since the plugs are direct plug-ins. thanks
Old Jul 23, 2003 | 11:15 AM
romeo619romeo's Avatar
Default Re: greddy kit installed b16A 5th gen (spooned out)
1 i used the FPR vacuum and the rear vacuum line of the intake manifold
2 either ignition wire will work..
3 the diagram for wiring would be different.. you have to use the 92 95 diagram..request it from greddy.. and you still can use the blue box
Old Jul 23, 2003 | 10:40 PM
thanks
NXAccordTO4B
Jul 24, 2002 08:52 AM
NXAccordTO4B
Jul 23, 2002 12:05 PM
NXAccordTO4B
Jul 23, 2002 11:35 AM
