Engine Puzzler
Old Aug 3, 2001 | 07:55 PM
Bnjmn's Avatar
Default Engine Puzzler
I have a 1991 Honda CRX DX with a problem. When the car hasn't been used for a while (30 minutes minimum), it starts and runs fine. However, if the car warms up and is turned off, and you attempt to restart- it is very difficult. All kinds of weird cranking intervals and incantations are needed to get it running. When it starts running, a whole new set of problems arise- the engine won't rev past 3500rpm, it seems to have about 10 hp total, it uses tons of fuel, and it runs hot (temp gauge goes a bit above its normal perch), and it throws a code 8 (TDC sensor). I changed distributors but that didn't fix anything. Essentially it seems that a "choke" switch is stuck on. I've been able to get it out of this "mode" by downshifting to get the revs above 3500rpm.
Any ideas?
Thanks
Ben
Old Aug 4, 2001 | 12:10 AM
B16A1-EF9's Avatar
Default Re: Engine Puzzler (Bnjmn)
That's really wierd man! I have no ideas...but I'm definitly interested in hearing some from others. This post should get it back on top again.
Old Aug 4, 2001 | 11:45 AM
BreakStuff's Avatar
New User
Default Re: Engine Puzzler (bandit_sir)
Hey does this sound familiar to any Honda Tech's out there? : )
you need to check your "Main Relay" when the car is acting up..
It is located underneath the dash on the far drivers side, its a little black box that will have a 8 ( i think, no more than 8) pin connector..
If the car acts up, tap on the relay...don't beat on it...just tap it to see if it clears up the problem..
Main relay supplys signal to the fuel pump, injectors and ecu and we replace these all day long when the weather gets hotter...
Rickweath
Jul 23, 2018 08:34 AM
spcasey
Aug 29, 2013 11:24 PM
journeyquest
Feb 18, 2013 09:11 AM
1997accordSE
Feb 11, 2012 07:58 PM
leviathan4444
16
Jul 11, 2006 10:17 PM
