SI head on DX
Old Jul 23, 2003 | 07:57 AM
Dorifto13B-T's Avatar
Default SI head on DX
If i was to put a si head on my lil brothers ef9 which is a dx what else woul i need to make it run properly
or could i put the head on there place his old ditrib back on the and his DPI and run off the dx ecu and id be fine right?
Old Jul 23, 2003 | 09:10 AM
Vinceg99's Avatar
Default Re: SI head on DX (wyt r1ce)
Yes the heads are alomost identical there is a little difference in the cams though. But yeah if you put the Si head on it and then bolted everything onto it it would be just fine.....Why dont you pick up everything to do a DPFI to MPFI swap though if you are doing all of that work swapping heads?? If you need more info use the search button in the upper right hand corner there have been tons of topics on this and the MPFI swap.
Old Jul 23, 2003 | 11:42 AM
89dxhunchback's Avatar
Default Re: SI head on DX (Vinceg99)
A Si head swap and mostly MPFI swap on a DX motor will boost top end power GREATLY !!! Only thing that gave me more power than the MPFI swap was the 75shot... hehe.
Old Jul 23, 2003 | 11:53 AM
Default Re: SI head on DX (89dxhunchback)
awesome thanks yall. i love this site. fark hondaswap.com
Old Jul 23, 2003 | 12:09 PM
essex's Avatar
the head is the same....just the cam is different.
eh2..765
Apr 28, 2005 06:25 PM
Josho_17
Mar 16, 2003 10:35 PM
mafioso102
Oct 11, 2002 01:40 PM
projectcrx
Feb 13, 2002 04:01 PM
maximedx
Dec 5, 2001 09:07 AM
