Throw Out Bearing
Old Jul 23, 2003 | 07:48 AM
CircuitFG's Avatar
Default Throw Out Bearing
Ok, I searched on this. . but i didn't exactly find what i needed. . I just installed a new throw out bearing when i put in my new clutch and flywheel. It was just recently. Like maybe a month ago. Now, it kinda makes a little errr sound every now and then. Could i need to increase the play on the clutch?? Or do you think its a bad tob?? i dont want to replace it! I have a 90 Integra with a cable clutch. .
Old Jul 23, 2003 | 08:14 AM
91integraLSVTEC's Avatar
i have the same problem.. i didnt replace my throw out bearing, i thought that was the reason why.. i hope somebody has the answer to this..
Old Jul 23, 2003 | 09:34 AM
CircuitFG's Avatar
Default Re: Throw Out Bearing (CircuitDA9)
anyone?
Old Jul 23, 2003 | 12:53 PM
delslow94's Avatar
well it could be ur pilot bearing..did u change that? its the one on the flywheel. if u did then id be afraid it might be the input shaft bearings on ur tranny. my buddy had that noise and we had to get him a new tranny cause doing all that tranny work sucks
Old Jul 23, 2003 | 01:19 PM
preluder's Avatar
Default Re: Throw Out Bearing (delslow94)
Is the throwout bearing lubricated well?
Old Jul 23, 2003 | 01:56 PM
CircuitFG's Avatar
I changed my pilot bearing. .and i lubed up the tob pretty well. . .Could it be an adjustment???? If it was the input shaft, wouldn't it have been doing it before the clutch as well?? It didn't happen until after. Might it just be an adjustment?? it seems that the tighther i have the clutch, the more it sounds. . . i've just been loosening it little by little. .
Old Jul 23, 2003 | 04:56 PM
91sr20ser's Avatar
Default Re: (CircuitDA9)
did u replace the flywheel or resurface it?
r.f.b
13
Nov 2, 2017 06:45 AM
jfrye
14
Apr 26, 2005 03:57 AM
red civic standard
May 25, 2004 12:49 PM
DJ_SaNdOz
May 6, 2003 03:06 PM
Ham'ed Hatch
17
Apr 20, 2003 06:21 PM
