damn, did you know this about camber?
Old Jul 23, 2003 | 07:20 AM
austrian type-R's Avatar
Default damn, did you know this about camber?
I did and camber and toe setting today. I was going to sit into my car when my camber was at -1.5 all around. The camber showed -2 degs on right front side when I was sitting on the driver side. I was very confused, cause I thought camber would be increasing on that side I sit.
I setted it at -1.5 degs camber all around and toe front ZERO, toe out in rear 0.09. Is that good for road/track race?
When I adjusted the toe in the rear, camber was coming out at -2 degrees. Well, I will life with it, cause I did 3 hours camber/tow setting. I was tired of this ****.
If you adjust toe in front, camber will not change. If you adjust toe in the rear, camber will affect.
I don' get that toe in out story. I did a search and read about 20+ threads. Finaly I know less now than before I read all the statement .......should I toe in or out for ttrack racing and road racing.
I think my camber is a cool mix for road driving and some open track days. But what's about toe. In or out? in front or rear.
Old Jul 23, 2003 | 07:42 AM
Chris N's Avatar
Default Re: damn, did you know this about camber? (austrian type-R)
Toe out in front for track. at the very least at zer in rear.
Mine is set at 0.07" out on each front tire.
In the rear, I have zero toe, and was told by someone I would call 'knowledgable' that upon turn in, zero toe becomes 0.04" (1/25") toe OUT, the trailing arm allows this 0.04" difference in toe.
the metric system would work so much easier than all this SI crap.
Just set it at 3-4mm total toe out (1.5-2mm each side) in front and zero in rear.
Understeer
Jul 11, 2005 05:09 AM
TypeR II
Suspension & Brakes
Jun 3, 2005 02:21 PM
acatak
Apr 26, 2003 07:13 PM
WheAs MaI MojO
Oct 11, 2002 08:06 PM
yoshi234
Dec 27, 2001 01:11 PM
