bsq's diy icebox
Old Jul 23, 2003 | 12:22 AM
Loveless's Avatar
Default bsq's diy icebox
I really have to use the term "diy" loosely because I bought the kit from bsq instead of making my own.
I'm still on the white, stock filter because the K&N filter is still in transit. I noticed a funny/burning smell after I installed this, maybe it's from the bust since I haven't used it for 4 months or so.
Old Jul 23, 2003 | 12:40 AM
Vtecfool's Avatar
Default Re: bsq's diy icebox (Loveless)
damn, looks good . Notice the gains? How does it sound???
Old Jul 23, 2003 | 12:53 AM
Loveless's Avatar
Default Re: bsq's diy icebox (Vtecfool)
human body parts are the least accurate form of measurement tools and it sounds stock
btw I think I found the problem to the smell: I left my coolant reservoir on the header and it melted, god what an idiot.
Old Jul 23, 2003 | 01:04 AM
KitKat's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Loveless &raquo;</TD></TR><TR><TD CLASS="quote">human body parts are the least accurate form of measurement tools and it sounds stock
btw I think I found the problem to the smell: I left my coolant reservoir on the header and it melted, god what an idiot.</TD></TR></TABLE> dont worry i done that twice, once when my friend help me install the air fliter and another time was when we install the carbon fiber hood because of the hood pins
Old Jul 23, 2003 | 01:44 AM
dLo GSR-stolen-now-WRX's Avatar
From: kyoto sangyo daigaku, kyoto, japan, sometimes bay area CA
Default Re: bsq's diy icebox (KitKat)
good to see another DIYer
Old Jul 23, 2003 | 03:51 AM
ebelp's Avatar
Default Re: bsq's diy icebox (dLo GSR)
Looks good. I'm sure it'll produce similar numbers to any CAI. I wouldn't like it sounding like stock though. The growl of my AEM ownz me.
Old Jul 23, 2003 | 04:25 AM
TheRoxorcist's Avatar
Default Re: bsq's diy icebox (ebelp)
it looks just like mine you're gonna enjoy it.
Old Jul 23, 2003 | 05:33 AM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
I have the same setup w/ K&N and it makes a little growl under WOT.
Old Jul 23, 2003 | 05:35 AM
lustedp's Avatar
id rather here my engine itself roar
Old Jul 23, 2003 | 06:07 AM
redlinegsr's Avatar
Default Re: (lustedp)
how much did you pick that up from him for?
Old Jul 23, 2003 | 06:15 AM
Brad's Avatar
Default Re: (redlinegsr)
BSQ sells em for $30 shipped
http://www.geocities.com/bretq/icetake_cai.html
Old Jul 23, 2003 | 06:22 AM
Sliminem's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dLo GSR &raquo;</TD></TR><TR><TD CLASS="quote">good to see another DIYer </TD></TR></TABLE>
i second that motion
Old Jul 23, 2003 | 06:32 AM
IntEGNYC's Avatar
Default Re: bsq's diy icebox (Sliminem)
and its probably safer than a CAI with the filter behind the signal lights.
Old Jul 23, 2003 | 06:41 AM
janet.k2's Avatar
nice, simple upgrade, you can't beat that!
Old Jul 23, 2003 | 06:54 AM
MooreBoost's Avatar
You said it, not me. How do you like your grounding kit?
gmoore
Old Jul 23, 2003 | 08:05 AM
P1mpSlap's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Loveless &raquo;</TD></TR><TR><TD CLASS="quote">btw I think I found the problem to the smell: I left my coolant reservoir on the header and it melted, god what an idiot.</TD></TR></TABLE>
ROFL
Been there done that. High Temp plastic owns you! rode around like that for like 2 days before I discovered it.
Old Jul 23, 2003 | 08:23 AM
DB8_TEG's Avatar
Looks nice and clean, stock look
One question, how does that mount to the bottom of the stock box?
Old Jul 23, 2003 | 08:25 AM
Loveless's Avatar
Default Re: bsq's diy icebox (P1mpSlap)
I taped a gatorade bottle in replace of the coolant reservoir untilI can get a replacement
Old Jul 23, 2003 | 10:15 AM
integ22's Avatar
Lol i did the same after installing my HIDs, but I found out seconds after so not much damage just a little hole.
Old Jul 23, 2003 | 10:50 AM
One Bad GeeSeeR's Avatar
looks good i am in the process myself from switching to aem cai to the diy ice box since the stupid aem started to crack from that mounting point. i just have to find 3in pvc pipe thats 1/8 thick. cant find it here at home depot.
CArlo
Old Jul 23, 2003 | 11:37 AM
pnthr30's Avatar
Default Re: bsq's diy icebox (One Bad GeeSeeR)
I had a hell of a time trying to find thin walled PVC and PVC elbows. They didn't sell it at any home improvement stores around here (Home Depot, Menards, Etc.). I couldn't even find it at plumbing stores or distributors because by code, plumbing pipes need to be schedule 40 (1/4" thick). Anyways, I finally found some thin walled PVC pipe (straight), but it wouldn't fit tightly into the schedule 40 elbows......then I found out that irrigation systems somethimes use thin walled PVC, so I got lucky and found an irrigation specilist place near me and they had some schedule 35 PVC elbows....although they do not fit perfectly, they were much better than the ones from the Depot (slightly thinner). Then I used some plumbers putty to secure the fittings together (that stuff is like cement). I think the 1/8" PVC is called schedule 200 if I am not mistaken......it is available in other sizes, but not 3" diameter - at least around here. If you need more info, PM me......I might even have some extra PVC lying around (straight), but I am not sure. Hope that helps a little........good luck.
Old Jul 23, 2003 | 01:15 PM
JL 74's Avatar
Default Re: bsq's diy icebox (pnthr30)
so how much hp did you lose?
Old Jul 23, 2003 | 01:41 PM
The-LS's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by One Bad GeeSeeR &raquo;</TD></TR><TR><TD CLASS="quote">looks good i am in the process myself from switching to aem cai to the diy ice box since the stupid aem started to crack from that mounting point. i just have to find 3in pvc pipe thats 1/8 thick. cant find it here at home depot.
CArlo</TD></TR></TABLE>
home depot here has it, along with most other home improvement stores. It is not going to be right next to anything PVC. The thin walled stuff is for irrigation and drainage, look in that area usually by all the black plumbing stuff. The only problem I saw was its only being sold in 8' or 10' lengths.
Old Jul 23, 2003 | 01:45 PM
DUCK COMMANDER's Avatar
Default Re: bsq's diy icebox (Black-LS)
someone should definetly dyno
Old Jul 23, 2003 | 02:06 PM
pnthr30's Avatar
Default Re: bsq's diy icebox (JL 74)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JL 74 &raquo;</TD></TR><TR><TD CLASS="quote">so how much hp did you lose?</TD></TR></TABLE>
I don't have a dyno to prove it, but IMO I haven't lost any. It is the same set up as BSQ's........ask him.......or anyone else running this type of DIY....
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">someone should definetly dyno</TD></TR></TABLE>
The only dyno I have seen is against a ITR intake...this dyno showed some decrease in power with the DIY. However, the ITR intake is quite a bit different than the OEM intake and resonator setup that I took off my GS, and there are countless was to make, and mess up, a DIY. I have no idea what kind of setup the DIY in the dyno was. I think that BSQ's is pretty straight forward, simple, and would work the best.
Before you engineering types get your briefs all messed up and start to educate us all on the dynamics and air flow characteristics, lets keep this in perspective........this DIY mod cost about $20 (filter not included), which is substantially less than the real deal (Comptech Icebox). Further, as discussed to death on this board and others, an intake alone will do next to nothing (a few hp) at best, so in the whole scheme of things, the DIY version is a better deal for the majority of people, many of whom are not concerned about trying to muster EVERY ounce of power that we can. I am not knocking those of you who are into that, just saying that many are not........if you are, this probably isn't the type of setup you want to run - plain an simple. Spend the extra $150 to $200 and get those extra ponies.......
